mcm4090
There is a fairly new company that has been making sliders and skids for the Gen2 Xterra based out of Colorado . I copied some of his posts from anther forum to show work.
After almost a year of owning the X, I decided to do something nice for “HER” ….
I started with the rock sliders, …. I’ve been looking at many manufacturers and more or less all do a good job. At least the guys being sponsors here in this forum – they excel.
However, I wanted to do something different and to get the best out of the best – because it is for MY X. I noticed that in all designs the sliders are “stopping” before the body ends - under the doors. There is ZERO protection for the lowest part of the fenders on either side.
I see easily when getting over a sharp rock can damage your vehicle – and I wanted to get it right. So I did. I also understand why no one will do it. Because is a PITA to do such a thing. But for my X – I did it J
I was also looking at the fact that the supporting plates are in most of the cases flat. This will not help your cause is you wish to put a Hi-Lift under a slider. The bolts will snap right on. You got to have some support “under” to have a good change to lift that baby. Again, I understand why many manufacturers are not doing it …. Because the plates are not leveled (the front is higher), and is not easy. Also you have to consider that you cannot let the sliders touch the body of the vehicle. They should attach to the frame only. But I did it for MY X J
After some tries, I got what I wanted. Cleaned them really well, sand them and applied two coats of self etching primer, two coats of premium bedliner (I love that stuff) and two coats of duplicolor Graphite wheel paint (to match my rims and roof rack – that’s another story), put some “no slide” tape on it and done
I got them attached with Zinc-Plated Type F Thread-Cutting screws and they are as strong as they can be.
I got rid of the back mud flaps and I cut the front one to protect from all the rocks coming from the front tires.
Again I’m not aiming at any vendor out there …. They deserve all the props since anyway there are only few of them (all the rest do the J’s and T’s)
If there is a demand – I might seek the vendor status – but that is to be determined. In the meantime – if you have questions, please ask.
