Oasis HP1000 Compressor, Run Air tools w/o a tank!
keithro
SOLD SOLD SOLD
Selling an oasis HP1000 compressor. I was going to put it in my JK, but space is a little tight. This compressor makes the extreme outback magnum look like a sissy :). I bought it about 6 months ago and haven't used it. The previous owner bought it 2 1/2 years before me and never used it. He bought it from a buddy of his that used it in a bagged lowrider truck. The previous owner told me this one was rebuilt by Oasis and upgraded to their current specifications to run 60 hours before needing an oil change.
This will put out enough CFM to run a 1/2" impact gun with out a tank. Will sell for $475 shipped CONUS.
Look at this comparison test where the oasis is as fast as the C02 tanks and faster than an engine (belt) driven kilby system: http://www.offroadair.net/4WD-0502-Air-82-85.pdf
Here it is running:
http://www.youtube.com/watch?v=HLhNpcn-uzA
HP1000 Air Compressor Specifications
DIMENSIONS (LxWxH) 17"x7"x10"
NET WEIGHT (Lbs): 45
SHIPPING WEIGHT (Lbs) 49
MOTOR TYPE: SERIES WOUND
MOTOR THERMAL PROTECTOR: Yes
Performance @ 12Vdc
MAX PRESSURE: 200 PSI CFM CURRENT
MAX. RESTART PRESSURE: 200 0 14 120
HORSEPOWER: 2.5 50 9 150
CURRENT AT MAX LOAD (AMPS): 200 100 8 180
POWER AT MAX LOAD (WATTS): 2400
Duty Cycle (%) @100psi @70 deg 30
Performance @ 24Vdc ***
MAX PRESSURE: 125 PSI CFM CURRENT
MAX. RESTART PRESSURE: 100 0 25 130
HORSEPOWER: 4.5 50 17 160
CURRENT AT MAX LOAD (AMPS): 200 100 16 190
POWER AT MAX LOAD (WATTS): 4800
Duty Cycle (%) @100psi @70 deg 15
jeep-N-montero
This is an amazing piece of equipment, I used a friend's Oasis once and it only took 40-50 seconds for each tire to air my 33x12.50's from 12psi to 32psi, he also demonstrated using a 1/2in impact with it.
lkretvix
