OEM Wheel make over!
redraif
The uphill battle begins
So I have had some good momentum going with fixing up the Sport. I decided to keep going with it.
Even though it was right around 32 degrees this weekend on Sunday... I got out there with a rain suit on and gave him a bath. I worked on getting the splattered mud out of the engine bay.... ummm yeah that is not working.... even scrubbing the underside of the hood, the red clay stains are still there.... So I moved on to getting more of the clay off the undercarriage. Well I had a good solid hour with the hose on full jet spraying up into the frame rails, boxed A-arms, suspension cross member, front frame support... etc... it was nothing but solid orange pouring out. I still need to get some more spraying done in the rear, but I was spent after all that, cold wise. So I will go at it again on a warmer weekend.... with a wire brush and scrub, cause simply spraying is not enough. On I side note... I took it for a drive on Monday and it might have been in my head, but I think it was handling a bit better. Maybe all that clay in the a-arms was affecting the feel of the suspension? Anyway...
I wanted to get as much done as possible, so I decided to jack the rig up and remove the wheels. I got all 4 off and scrubbed the wheel wells. I got the wheel wells clean enough to paint with semi gloss black.
Just that little bit helps so much, once I get the fender splash guards reinstalled it will make all the difference in covering up the clay stained suspension.
So I then took a good look at the wheels. The factory finish looked ok from 10 feet away, but it had definately seen better days. There were scratches on each wheel. The insides have obviously never been washed ever. There was so much caked on grease and dirt. There were even rust spots.
I scrubbed them with dawn and a scotch brite pad and got them as best I could. But the finish was beyond hope.
That was no fun in the cold. The dang wash mit I had used on the truck froze solid drapped over the fence is was so cold.
It was now judgement time. What to do with the finish? I rolled the rims into the garage with 2 space heaters. I stood the rims up with the heaters blowing on a pair each. They warmed up enough that I felt they could take paint. So I went forth with my original plan to paint them satin black.
I have never been a fan of solid black rims on any vehicle. The all black against the tire always makes them look dirty. So i decided to add a color keyed lip to the rim.
I think the gloss white lip made them pop and gave the transition between the rim and tire to keep the tire from looking bad.
redraif
I was debating what to do with the center caps, believe it or not the clay over the years had stained them orange.
I wanted to Black chrome them, but they were in no condition to take the finish and even look right.
So they got satin black too.
My lug nuts were even stained orange. Crazy! I sanded them and painted them satin black as well. Overall they came out extremely well.
Here they are installed!
redraif
Thank you! Trying to reverse all its abuse from the previous owner is a challenge... UGH!
PirateMcGee
I've been wondering how the stock wheels would look in black. Looks awesome! You're forcing me to do my wheels now.....
Also do any of your center caps rattle slightly? I have one that does and it drives me insane.
redraif
Thank you! I searched to see if a bunch of folks already painted theirs black. I only found a few and they were solid black... so I added the color key for that reason too.
I went by my vinyl shop yesterday to see about them making "mitsubishi" for me to go on the back over the raised letters on the back hatch. Mine are looking rough and the black plastic section is graying like everything else.... so I was going to repaint it and use vinyl to put the "mitsu" back. Anyway.... he asked me if I just installed new rims.... lol. So I guess that means they came out pretty good in person too... lol
You know I have been wondering what the dingle dingle is up front.... I had one cap that is very easy to take on and off just by hand... I wonder if that is it? Does yours make a ting type noise?
Maybe I will pull that one off and see if the noise disappears.... hmmm...
Sabre
Overlanding Nurse
What prep did you do for this project? I'd be interested in seeing this thread updated periodically as you put some miles on the truck. Thanks for sharing...they really do look great.
redraif
The prep consisted of washing them in dawn. Then scrubbing them with a red scotch brite pad with dawn. Then I dried them. Heated them to a good ambient temp since it was at freezing temps outside. I wiped them down with wax and grease remover till I had a clean towel on my wipes. I then sprayed the back with some of the duplicolor rust convertor. Let that dry. Then sprayed the back with the semi gloss duplicolor. Let them flash. Laid them down with the face of th he wheel face up. I taped the tire surface. Then I wiped the face with additional wax and grease remover. Then I let the paint fly! I had a few spots that wanted to fish eye. The second coat corrected that issue and you can't see it on the finished product.
Thank you!
I did a similar process on my civics wheels. They were completed about 5 years ago I believe. The finish was gloss black. It was not gloss enough to satisfy. The gloss did not hold. It turned to a semi gloss. It's why I went with a semi gloss this time. As far as how the civics wheels held up. They were still looking good (outside of the finish matteing) until a crap tire shop dropped 2 of them off the mounting machine multiple times and then refused to repair them. Even still the finish held and did not chip or peel outside of the initial damage. Now the prep on those wheels were more intense. Those wheels were highly damaged when we bought them used. I actually stripped them and sanded out curb rash and gouges. They were so bad they had to be primed fully and sanded multiple times to fill the scrapes.
Clemtiger84
