Off-road Toy Hauler/Trailer - Custom Built
rlafaye
Asking $9000
One of a kind custom trailer designed and built here in Colorado by passionate off road enthusiasts. This trailer was built by me and a buddy so we could venture as far as possible in the Overland rig and haul our dirt bikes. It was designed to haul dirt bikes, but may also accommodate certain ATVs or other toys. But it doesn’t stop there. The trailer is also fitted with a rack for attaching a Roof Top Tent, large front storage compartment for all your gear and 36 gallons of fresh water storage. That's right. But why would anyone need that much water? Because this trailer also has an on demand hot water shower system. You heard that right. Go ahead and ride all day. Come back to camp and wash your massive man balls in bliss as you think about how much you shredded today. Then sleep clean in comfort and do it all over again the next day. Besides some local testing, It has really only been on 2 long trips. One trip to Moab and one trip to Death Valley. It performed flawlessly on both occasions while fully loaded.
Specs are as follows:
* Full steel construction - no wood
* 4x8 deck surface with aluminum tread plate
* 13' long x 6'1" wide x 6'9" tall (without tent)
* Tires - 255/85R16 BFG Mud Terrain KM2 tires - barely worn
* Wheels - Pro Comp series 69 - 16x8 - Toyota/Tacoma Bolt pattern
* 3500 LB straight axle - leaf spring suspension
* Max coupler trailer hitch - 360 degrees of motion
* Full LED lighting (no plate light) - 4 pin connector
* (2) 18 gallon water tanks connected together
* 5 LB propane cylinder w/mount
* Jerry can mounts for (2) standard 5 gallon cans
* On Demand Hot Water Shower mounted in custom weather tight enclosure
* 12V pump with dedicated 72000 mAH battery bank
* Does not include RTT but may negotiated if desired
* Ramp included for loading dirt bikes
* Heavy-duty Rear stabilizers for leveling/balancing
* Title in hand
Will sell for $12k with James Baroud Tent. Otherwise, $9000 w/o tent
James Baroud Tent:
James Baroud Evasion Evo is one of the best hard shell tents on the market. It's been on many camping trips but is in great condition. The shell has seen the elements but there are no issues with this tent. Super comfy 3" memory foam mattress. Shell will completely close with sleeping bags and pillows in the tent! Look up more specs here: https://www.jamesbaroudusa.com/product/james-baroud-evasion-roof-top-tent/
