One of a Kind RRC Trailer
DWphoto
The Battle wagon is for sale!
I have used it a few times as a remote pit for desert racing, to haul firewood/ and haul my Roof top tent around. It's a cool little trailer the rear tailgate and doors all work. I have already taken this trailer down some rough roads. It would be perfect for a RRC owner. Use it to haul your gear to the trails set up a base camp. Perfect for weekend trips like Pismo / Shaver Lake/ National Rally/ Rover Rendezvous
It's got some scratches a few dings.
It has a 3 inch lift springs OME on 33s.
All of the fab work was done by Maxyedor
It tow perfectly straight/you can barely notice it back there.
You will need a pintle hook for your tow hitch.
$800 obo
*No the tent is not included
Elliott
I'm in Thousand Oaks, CA
818.968.0945
elliott.strickler (at) Gmail (dot) com
or PM me
DWphoto
That's brilliant, plus you could canibalize the trailer for spare parts if you were in dire need of an axle, spring, or door handle :)
very true....you could have a spare 3rd member bolted in to the axle.
If you are pulling this thing you have room for one of everything..
Like is said in my original post I used if as a remote pit for desert racing.
I have had:
6 spares ( 33 and 35 in tires)
jack stands
Welder
plasma torch
generator
Floor jack
Dump cans
Fluids
Tools
A table.
BBQ
Firewood
and still had room for stuff.
I forgot to mention
Trailer has new shocks. Also the floor is hinged and has storage bin were gas tank was perfect size for a 1550 pelican.
mor4wd
Who is Maxyedor. And if you dont mind me asking, what did he charge you to make it into a trailer?
RusM
That is an awesome idea! As a Toyota fanatic, that would really give me a boost to be constantly 'recovering' a RR!
DWphoto
Hes a fellow forum member, as well as my roommate. Trailer cost materials/ case of Zima if we built another one probably charge $2000
Max and I parted out the truck and the cut it in half. He welded the tongue and front of the trailer.
we talked about making these trailers and selling them but there is no demand
If would like to come scope out the quality of the work swing by and check it out the trailer. You can also see the roll cage his discovery he just finished / custom radius arms and coil overs
Let me know
E
MaxYedor
x2 Who is this mythical character?
The RRC trailer is pretty sweet, it gives you a couple more cubic feet of storage space than an extra-cab Ford Ranger's bed. Works great on trips with a central camp, there's enough room for one of those giant white coolers that holds 500 beers, enough fire-wood for a month and then your RTT can mount on the little internal rack. Also worked bitching at the Desert Clean-up in November, much rather fill up half a Range Rover with trash than a full one you still have to drive home. Beats a $10k Adventure Trailer, cheaper, more versatile, lighter and carries more goods.
This is the most recent thing to come out of the garage
Houie
