Online vendor for Larsen 2m antennas needed
Desertdude
Sorting out the 2m antenna thing - anyone have a fav vendor online?
Can anyone reccomend a specific 2m Larsen/mount ant in their catolog ?
Desertdude
yer fast -Hey thanks that helps - what type of mount are you using? I read on larsens site that style antenna is a 3/4" hole mount ? Trying to get a visual :)
asteffes
NMO is a style of connector, available on different types of mounts. For example, I have a magnet-mount that sticks to the roof with a magnet, and has an NMP connector on top, onto which I screw on the Larsen antenna. An NMO connector is about an inch in diameter, but that doesn't really matter.
You'll need to choose a mount that works for you - either a magnet, a hood lip, or maybe a roof mount that you would have to drill an actual hole for. An in-roof mount provides the best ground plane, but if you're like me and don't want to put a hole in your roof, a magnet mount is a good alternative. Just be aware that that antenna is about 3 feet tall, and can get caught on low-handing brush. If that's a concern for you, you might want a rubber duck style antenna with an NMO mount. They're shorter and more flexible to avoid hangups, but have a little less RF gain.
Desertdude
On one of my trucks I will do the hole in the roof to get the most GP - the other I will hood lip mount it - I am getting closer to understanding Larsens PDF codes - thanks for the guidance :beer:
