Only One Green Light Showing-Need Help 2003 Limited
JumpJ
When I turn the key on normally the two rear wheel drive indication lights come on. These are the lights that when I shift into 4WD go four green. I cam off a camping trip last week and only one of the lights is showing green in 2WD.
Has anyone had this problem. Anyone got any ideas on how fix or should I be worried?
Thanks in advance.
earljuic3
I have this problem, need to pull gauge cluster and replace bulb is all.
Sent from my LG-V410 using Tapatalk
Sabre
Overlanding Nurse
They're really useless lights. What are they telling you, that you're in two wheel drive? It's like having a lamp telling you that the engine is running: completely unnecessary.
When I replaced mine with LEDs I left those bottom two out. Now I get two green lights in 4wd and the rest of the time it's dark.
Goldenbora
