ORO Sway Loc - 300
hollaback55
i have the following pieces for the oro swayloc system, will fit TJ or Jk depending on whether or not you get spacers
frame bushings driver and passenger side (brand new)
torson bars inner and outer (brand new)
Swayloc arms driver & passenger (used but in good shape)
what you'll need to get
link ends to attach from the arms to the housing tabs (heim joint units, link bar's) - i believe it'll be about $60.00 bucks
flip lever or air system. IMO flip lever is much cheaper and just as easy ($20.00)
spacers if using for on JK ($15.00)
nuts and bolts to install ($20.00) roughly
on the passenger side arm one of the bolts the flip lever uses to attach to the arm broke off so it'll have to be removed, easy to do, but just didn't get around to it.
call OffRoad Only to verify costs, they might have changed.
can ship, just need zip code.
