Overland Explorer Vehicles Camp-X | $42,800
Basil.
2020 Overland Explorer Vehicles Camp-X (with Aluma-Tray Upper side Boxes for the CampX fitment!)
  • Asking Price: $42,800 firm. ($47,000 with Aluma Tray camper boxes)
  • Color: White and no OEV/Camp-X graphics
  • Located in Southern California
The camper is 2 years old and in Exceptional condition. The reason for selling is the customer is upgrading to the larger flatbed HBE camper. The Camp-X is available with or without the upper storage boxes that mate it to the OEV Aluma Tray
Email is best if you're interested!
Basil@basilsgarage.com
Specs
  • External Dimensions: 140” L x 78” W x 62” H (closed) / 84” (open)
  • Internal Dimensions: 137” L x 74.5” W x 82” H (open)
  • Powder Coated Aluminum Extrusions
  • OEV Gen 3 Composite Floor, Walls and Roof (>=R8)
  • Fire Rated & Insulated Soft Walls (>=R4)
  • Locking Roof Supports/hinges Front and Back
  • Gas Struts Assist for Lift
  • DOT LED Lighting
  • Dry Weight: 1200 lbs (does not include the weight of the jacks)
Features​
Plumbing/Heating/Cooling:
  • Truma Aquago Hot Water Heater
  • Truma Vario Heat w/thermostat
  • 10-speed roof vent w/roller blind
  • 20-Gal freshwater tank w/12v pump
  • Bullfinch outside shower on the driver's side
  • UPGRADED SINK: ROVOGO 20 x 16 x 9 in. Drop-in Kitchen Sink; Stainless Steel. Black Glacier Bay faucet and soap dispenser. Installed professionally by Off-Grid 4x4 in Boulder Colorado)
  • Dometic Smev cooktop w/flush mount glass top
Electrical:
  • 180 W Solar Panel
  • 200 W Solar Panel (added in 2023 by Off-Grid 4x4 in Boulder, Colorado)
  • USB plug (dual outlet)
  • 12V auxiliary connection
  • LED entry light
  • LED interior lighting
  • Redarc: The Manager 30 w/display
  • Victron 100Ah AGM battery
Other:
  • OEV awning mounting kit
  • OEV Molle rear accessory rack -driver side
  • OEV Molle rear accessory rack -passenger side
  • OEV King Bed Extension.
  • Dometic crx65 built in fridge
  • Dometic seitz side window
  • Screen door
  • Entrance door grab handle
  • Aluminum propane cabinet w/10 lb bottle + extra 5lb bottle
  • C-shaped dinette folds down into bed 38”x77”
  • Marine grade fabrics
  • 3” medium density foam cushions
  • High traffic grade vinyl flooring
  • Structural powder coated aluminum interior cabinetry
  • Fire extinguisher
  • LP detector
  • Smoke/CO detector
  • Thermo break foam kit
  • (4) manual rieco titan jacks
  • Roof rack ready “L” tracking
Custom Options​
All custom options have been installed professionally by Offgrid 4x4 in Boulder Colorado.
  • Xantrex Prowatt Sw1000 Inverter
  • WeBoost Drive Reach OTR (Cell Phone Booster)
  • Baja Designs S2 Sport, Work/Scene, LED, Amber x 4 (lights are installed all around the camper and controlled from inside)
  • RVLock Keyless Entry Handle (Make your life easier and open the door with a fob or using the keypad.)
  • SP-9100 Switch Panel Power System (To control the lights, water pump and WeBoost)
  • Folding Grab/Step x 6 (Installed in the back of the camper and on the solar mounting bracket as handles for easy access to the roof and items mounted on the MOLLE panels)
  • Custom shelf (Installed inside the “porta potty” cabinet to improve storage. it's easily removable)
  • Alu Cab 270 Shadow Awning
  • Alu-Cab Shower Cube
  • Wired for Unique Componentry's Starlink roof-top flat mount, including mounting plates for magnetic feet. (Starlink NOT included)
Please note the items mounted on the camper (MaxTrax, Shovel, chainsaw scabbard, and Pull-Pal, custom interior storage nets and system) are NOT included in the sale.
Known Problems​
Outside​
  • Minor scratches here and there because of branches on narrow trails. Nothing serious.
  • The door to access the propane bottle is a little finicky to close (you have to bang it). I think this is a known problem on the 2020 Camp-X. OEV changed the door on their newer models.
Side Boxes:
Aluma-tray Upper side boxes for Camp X fitment. To be mounted on the 6.75' AlumaTray.
Basil.
More photos
gp01
