Designed and built for a multi-continent overland trip – equally at home on more local adventures!
UK BASED: My 2015 Hilux is for sale, it’s been converted into an Overland Camper in mid to late 2024 to do a trip to Europe, The Balkans, Turkey, Georgia, Armenia, Scandinavia, Iceland and North Africa. I have had to cut the trip short for personal reasons. However, the Hilux did 8000 miles over 4 months and never missed a beat.
I have owned the car for 4 years and I have known it since it was 6 months old. It’s never been used commercially and is in outstanding condition.
Furthermore, every single modification and preventative maintenance item has been thought through to make this the easiest dual cab pick up to live out of on an overland trip, off grid. It’s been built with massive OCD and sometimes re-worked modifications again and again to get it right.
The result has been a wonderfully easy vehicle to live out of, to get off grid but with little compromise regarding on road stability and ease of getting through massive road miles.
It’s a reluctant and genuine reason for selling, but it was built for a purpose and is 100% ready for its next adventure. Just been serviced again at 138k miles.
Vehicle History
Total around £50,000. So, it “owes” me a LOT of money but I am being realistic about my asking price of £27,000 and I can deliver anywhere in the UK if needed.
It is the most well thought out vehicle I have seen, and it’s a pleasure to travel in and live out of.
Vehicle History
- September 2015 (65 plate) RHD, Hilux 3.0 D-D4 (the legendary 1-KD-FTV engine) manual gearbox.
- UK MOT Until April 2025
- My friend owned the car from 5k miles until 76k miles. I bought it 4 years ago and mileage is now at 140k miles. The last 10k miles of which it has been performing flawlessly on an overland trip.
- The vehicle has full-service history, and a fully stamped up service book
- 2 keys present and UK V5 registration document in my name
- Please note the private number plate will not come with the vehicle. It will revert to original number place SG65JXM
- Cruise control, air con, black leather.
- New front wheel bearings
- New front brake callipers
- New brake discs and pads
- New rear brake shoes
- New brake fluid
- New sump (massive job)
- New front driveshaft seals
- New timing belt and water pump and timing belt tensioner (128k miles)
- New ancillary belt
- New ancillary pulleys
- New Alternator
- New air conditioning compressor & re-gas
- 2 new (uprated) starting batteries (Yuasa)
- New power steering pipe assembly
- New intercooler
- New intercooler hoses
- New radiator hoses
- New clutch and new release bearing (118k miles)
- Front diff oil changed 128k miles
- Gearbox oil changed at 128k miles
- Transfer box oil changed at 128k miles
- Rear diff oil changed at 128k miles.
- Power steering fluid changed at 128k miles
- Coolant flushed and changed at 128k miles
- New exhaust from CAT back – middle section and rear section
- New lower suspension arms – heavy duty Pedders ones from Australia
- The vehicle has been undersealed annually, most recently in April 2025 with a full wash, needle gun and strip back, followed by 2 coats of Lanoguard (including inside chassis legs and sills.
- Beeping when key in ignition and door open de-activated.
- Beeping when driver’s seatbelt not on has been de-activated
- New batteries in both keys.
- New SCV valve fitted
- Superchips re-map circa 200bhp and more economy and torque
- New tailgate supporting straps (OEM 250KG rated)
- Front wheel bearing
- Rear wheel bearing
- Outer front CV joint
- Wheel studs (5)
- Wheel nuts (5)
- Universal joint for front prop shaft
- Universal joint for rear prop shaft
- Spare nuts and bolts for front prop shaft
- Spare nuts and bolts for rear prop shaft
- 2 x Fuel Filters
- 2 x Air filters
- 2 x Pollen filters
- Self-amalgamating tape
- Various hoses, clips, nuts, bolts, fixings etc
- Spare matching alloy wheel with matching BF Goodrich All Terrain tyre
- Original underslung spare included also with new Geolander tyre fitted.
- With the weight and the suspension kit, the original bottle jack is no good. Will be supplied with brand new Mercedez Sprinter van bottle jack
- Spare fuel hose and clips
- Rear seat delete. Area houses storage boxes, AGM Leasure batteries & all charging infrastructure. And 45L compressor fridge/freezer (I still have the rear seat and belts and fixings etc which will come with the vehicle.
- Netting fitted on ceiling for storage of jackets, hats etc
- 2 x netting pockets fitted on rear window
- Front waterproof seat covers
- Secret storage compartment in the centre console
- Full set of customised Toyota OEM rubber mats
- Apple lightning cable hard wired and outlet is beside phone cradle.
- Front dash cam hard wired (no annoying cables dangling about)
- Garmin satnav – again hard wired so no cables in the way.
- Additional 2 x cigarette 12v outlets in the front with 2 x 2 output USB charging
- Remote switch for 4 x STEDI security/camp lights on dash
- 2 x fire extinguishers fitted
- Kitchen roll holder fitted
- All interior lights replaced with LED bulbs
- Rear tailgate plastic ribbed cover replaced with custom made marine ply, with black “raptor” coating – great, slip free working surface!
- OME 40mm Suspension kit (fitted and set up by Overland Services in the UK)
- Shocks
- Springs (rear has greaseable shackles)
- Camber corrected upper control arms
- Rear springs are 400kg constant load
- ARB Sump guard
- ARB Gearbox and Transfer box Guard
- ARB Heavy Duty Side Steps/Rock sliders
- Devon 4x4 Fuel tank guard
- 4 x BF Goodrich All Terrain Tyres
- Snorkel / Raised Air intake fitted
- EVC Throttle controller fitted and hard wired
- Front A Bar fitted
- Front Spotlights & Light fitted, both work off full beam but can be separately isolated.
- Wind deflectors fitted on all 4 doors
- Alloy canopy fitted with 3 x HD roof bars. Canopy has been double nutted for vibration resistance and also additional waterproofing – it’s the first canopy I have ever had that doesn’t leak!!
- Dynamat fitted to interior ceiling of canopy – to cut down on resonance and noise when driving long distances.
- Canopy fitted with 3 LED lights internally
- Canopy fitted with 4 x 20W STEDI Camp lights (via a remote relay and can be switched from inside the roof top tent or the front seats of the vehicle).
- Thule roof bars on vehicle.
- 2 for safari rack
- 1x for custom wind deflector and 2 layers of heli tape to protect paint on roof (All bars fitted with rubber inserts to minimise wind noise.
- Safari roof rack comprising of:
- 4 x black Maxtrax recovery boards
- 1 x matching alloy wheel and tyre
- 1 x waterproof Peli case
- 2 x 10L HD US military grade (brand new) fuel cans
- Custom ladder mount for tent
- Custom mount for recovery shovel
- Extended diff breathers
- Extended Gearbox and Transfer box breathers
- All fixtures and fittings are aluminium or stainless steel where possible, to look good for years to come and be corrosion resistant.
- James Baroud SPACE EVO XL hard shell Tent.
- All noisy zip toggles have been removed and fitted with para cord.
- Comes with interior storage, interior light, Solar fan
- Fitted with optional anti condensation mat
- Custom ladder and ladder bracket. (Original James Baroud Ladder will be supplied)
- 45L compressor fridge/freezer
- ELECTRICAL SYSTEM – All “Victron Connect” and installed by qualified electrician
- 2 x 100aH AGM batteries (These will keep fridge and other systems going for 3-4 days off grid depending on the ambient conditions)
- Victron DC to DC charger and all protective systems
- 2 x high current 12v Cigarette lighter sockets (useful for compressors)
- 300W inverter – for laptop, SLR camera batteries, etc etc. It also has 4 USBC outlets. This system also powers the outside lights as well as the fridge freezer
- 60L “slant” water tank fitted with outlet tap at the rear of the tailgate.
- 330mm high, compartmentalised full-length drawers fitted. Professionally made by carpenter with 150kg full length slides per side.
- AluCab Shower Cubicle Fitted
- Tuff Trek SPEEDWING 270-degree awning fitted. Perfect for shade or protection from the rain!
- Induction hob and 15M cable with blue connector supplied. Save on gas when in campsites or cook in the wind with no problem!
- Camp table – adjustable height to eat at or stand up and prep food on.
- Diesel funnel
- Water funnel (to refill 60L internal tank)
- Levelling ramps for camping
