Overland Vehicle Systems OVS 180 Awning -- Seattle/PNW
Fourthint
Hi all,
I have an Overland Vehicle Systems OVS Nomadic 180 Awning for sale. It's been only used once. Comes with brackets. $550 OBO in Seattle. I'm sometimes near Portland as well.
Comparable to Roofnest, 23Zero, Alu-cab, Rhinorack batwing, Thule, Bush Company, Ironman 180 awnings. This awning is also self standing and does not require setting up the poles, which allows for really fast deployment.
Further details:
Features: 88 Square Feet of Freestanding Covered Shelter, 600D Poly Cotton Rip-Stop Cover, Boxed Aluminum Rafters, Pivoting Aluminum Adjustable Poles, Tie Down Points for Securing Poles and Water Run Off, 1000G PVC Travel Cover With #10 Zipper, Ballistic Nylon Tie Downs With S Connects and Buckle, Shock Cord With Retention, Zippers To Secure Enclosed Shelter, Heavy Duty Oversized Stakes
What’s included: 180 Degree Awning With 4 Built-In Aluminum Rafters , 3 Pivoting & Telescoping Aluminum Poles + 2 Telescoping Aluminum Poles, 4 Sets of Shock Cord, 4 Heavy Duty Stakes, Travel Cover, 3 Heavy Duty Mounting Brackets and Hardware, Nylon Reinforced Tie Down Kit
Opened: 240" x 78.5" Closed: 88” x 7” x 6”
Fitment: Anything with a factory or aftermarket roof rack. Please confirm rack weight capacity prior if you’re unsure.
Installation: Will accommodate most factory and aftermarket racks.
UV Rating Transportation Cover: PU-2000
When you’re looking for a quick deploying one-man operation awning that gives you 88 square feet of shelter you came to the right place. Unlike other awnings, our Nomadic 180 requires no poles to set it up because of the pair of reinforced oversize hinges and heavy-duty rafters. Our covers are manufactured out of 280G poly cotton rip stop material that has heat sealed seams which ensure you’re not going to see any leaks through seams regardless of the size of rain you’re dealing with. If you see the weather changing or something stronger than a breeze turns up, you can deploy the three pivoting aluminum poles and adjust to your desired height with a quick lock system in seconds. When its time to lock down base camp for serious weather, deploy the poles, secure the stakes with the supplied para-cord and put up the optional enclosure shelter and your ready to take on some the most severe storms. When its time to stow your Nomadic 270 away it takes minutes to break down and secures nicely in 1000g PVC cover.
At Overland Vehicle Systems, we're committed to helping you live your outdoor lifestyle. Our 1800 Degree Freestanding Awning is the perfect way to enjoy the great outdoors without sacrificing creature comforts. With a quick and easy installation, this awning will let you relax in the shade while enjoying panoramic views of the surrounding landscape. The awning can be used as a standalone unit or easily integrated into an existing vehicle. Whether you're looking to add some shade to your campsite or just want to enjoy the outdoors in comfort, the 180 Degree Freestanding Awning is the perfect solution. Order yours today and start enjoying the great outdoors
CharlieGreenT
