Overlaying USGS topos for GE help!
angusdevil
I've been using the USGS topo kmz at home and LOVE IT! Is there any way to convert the USGS topos and overlay them for offline use? I can convert the downloadable PDF's to most anything and it still be clear quality but when I overlay it in GE, the quality is drastically cut. Is there a setting I'm missing or does GE cut down the quality for overlays?
BirfMark
My understanding of Google Earth is that in order to use your own imagery (in this case the topos), and be able to use the software while not connected to the internet, you'd need the Google Earth Enterprise edition. I've got a couple seats of Google Earth Pro, and there is no way to use locally stored imagery 'offline' that I know of.
angusdevil
You can use google earth offline all day as long as the info is stored in the cache (2000mb limit). As for topo's, I'm not looking to link up to server, I'm creating image overlays that are linked to my harddrive so that they are used offline which I have done successfully.
The problem is that with image overlays, you can only use a photo no bigger that 2000x2000. This is smaller than a topo map so that requires cutting and lining it up. I was trying to see if there was a way that set a grid or another type of overlay so that it can pull up the full, hi-resolution quad instead of slicing it into quarters in order to make it fit.
Example - When you use the USGS Topo kml, it brings up a grid and you choose what quad you want. It doesn't load up a full resilution picture right away so it has me believing that it uploads a more detailed image depending what your altitude is set at. I haven't had a chance to tear apart the file yet to confirm this.
angusdevil
At first try, a pretty bare bones program but it looks like it'll do. Looks like you have to have to manually punch in the way points and have it overlay in order to make it work so that'll mean a little more work and trimming but that's MUCH better than going through and manually chopping up a file and then spend time trying to align it.
BirfMark
Depending on how many of the topo's you're trying to split up, I could probably do it pretty quick for you. The software I have can split up rasters & create the superoverlays automatically.
angusdevil
Thanks for the offer. I have a few hundred that I need to split up but its a long term project so I'm just hashing them out as I have the time.
