PA_JERO's Garage Sale
PA_JERO
I will be posting items slowly throughout the next week, most of these items are going to be Montero related with some exceptions. Please let me know if you are interested or have any further questions, you can either PM me or Email me @ Kevineverett85@gmail.com
First item up today...
Front and rear axles out of a 94 SR with 5.29 gear ratio and both have lockers. Will fit a Gen 1 with coils (89-91) or gen 2/2.5. These axles were built only 2 years ago and are still functioning inside of my 94 SR currently. I will be removing by the end of this month (May) and would like to have a new home for them to go directly to. These can be sold either by the differentials and shipped (buyer pays shipping) or if you can I suggest 100% complete axles but there will be no price difference. The rear axle will also include steel braided brake lines and fully rebuilt OEM calipers with Power Stop slotted rotors to make the rear complete. I have put a lot of time, money, and research into these axles. I believe these are the very first documented North American SR axles to receive the Hyundai 5.29 gears. This is a great set up for anyone looking to upgrade gear ratios, and those of you with a gen 2.5 need these. Reason for parting with these is my 94 SR is going a completely different direction. Dana 44 SAS with 4.88, which forces me to change ratios in back. So I'm doing a 4.90 and building an SR rear with an ARB instead of a factory locker for strength.
Price :$2500.00
Front: 5.29 R&P with all new bearings, seals, shims, and set up properly with an ARB RD110. This is a low opinion differential out of a gen 1 but will fit in a gen 2. Will also get steel braided brake lines, Aisin hubs, and 100mm CV's
Rear: 5.29 R&P with all new bearings, seals, shims, a newer good working diaphram to engage the factory locker, also properly set up. If you have an SR you may need to convert the pinion side of the drive shaft to a 9" end. Nothing complicated. Complete axle also gets steel braided brake lines and Power Stop rotors.
Hopefully I didn't miss anything.
I understand that this is a large chunk of money to shell out all at once and obviously shipping can be extremely expensive given the bulk of the items. I'm willing to sweeten the deal a little bit. And just to clarify with all, this is a drop in set up. No setting up of diffs, these are drop in ready to go axles and a huge upgrade for somebody trying to build a very capable Montero.
I am willing to ship within 400 miles of my location personally. Yes, that's right, if you pay me full asking price, I will drive to your house or meet you if your coming from a further distance as long as it's within 400 miles of my home. I can get to the center of Los Angeles CA and Albuquerque NM from my house. May be willing to travel a little further, but we would have to negotiate some additional money. Email or PM me
brad2274
If someone buys this and needs the 9" pinion side of the driveshaft i have one.
So will you be running 4.88 front with 4.9 rear? if so, thats any allowable amount on difference as long as youre offroad in 4wd right?
PA_JERO
4.88 front to 4.90 rear will be fine, that's what I will be running. Originally I was gonna stick with the 5.29 in the rear and go for a 5.13 or even a 5.38 up front, but did not feel very comfortable with that for some terrains. In the Sierras you drive over a lot of flat slick rock, I do not want to bind up that transfer case and risk breaking it.
PA_JERO
Second Item:
Daystar rear coil spacers for those who want a 2" lift and cranked factory torsion bars. Fits gen 1 or gen 2/2.5, not sure if they will fit a gen 3. They serve me no purpose anymore and need to go. These were used for about a year a few years back. Still in great shape
$80 shipped
These are what you get:
Toasty
4.88 and 4.90 are so close you could run them on the street in AWD but unfortunately PA_JERO and i no longer have AWD function.
brad2274
Ok so with my stock 4.625 front diff and swapped 4.636 rear SR axle i should be ok if i pop into 4HI in a monsoon on pavement?
(sorry dont mean to thread jack, ive just been told different things)
PA_JERO
I'll tell you what, I'll get over you thread jacking my post if you buy my 5.29 axles. Kills two birds with one stone. Then you no longer have to worry about a difference in ratio because mine are a matching set. Make me an offer.
