Paha Que Outhouse Tepee w/ Aluminum Poles SOLD
Overland Hadley
on a journey
Bought the Paha Que, only set it up once in my yard. Took it on a couple trips but it was never used. Complete set up, picture below is with out the rain cover over the top.
This is the Paha Que with Aluminum shock-corded poles, and sells new for $203.99
Selling for $120 shipped (in the USA, will ship farther for extra charge)
The Tepee, the camping industry's first fully equipped portable outhouse by Paha Que', provides a "common sense" evolution in campsite restroom and shower facilities. Featuring 67" vertical walls, floor measurements of 54" x 54", and a peak that reaches 94". The Tepee is lightweight, portable, and easily stows in a 8" x 26" zippered carry bag that weighs about 10 pounds. Easy to follow instructions sewn inside the carry bag promise a five minute one-person setup.
Features:
º"No-see-um" mesh roofing and bottom side panels were added to enhance ventilation
ºThe detachable heavy-duty, waterproof flooring engineered to allow drainage of shower run off and to keep the bugs out
ºRainfly includes unique clear vinyl panels, that warm the shower bag (not included) when rotated to face the sun
ºStows in duffel style carry bag with straps, 8" in diameter and 26" long
ºEasy one person set up in under 5 minutes
Specificaitons:
ºFloor Size: 54" x 54", removable
ºSize at Height of 5'6": 36" x 36"
ºInside height: 94" at peak
ºZipper Door Dimensions: 57" high x 32" wide, 8" off ground 4" Wide Netting Strip at Wall Bottom, Except Door
ºWall Netting From 5'8" to Top: Four 104" Poles, Main Vertical; Four 48" Poles, Top Horizontal
Materials:
ºSidewalls Fabric: 150D polyester oxford weave, with heavy-duty polyurethane waterproofing
ºFloor Fabric: 100% high-tenacity nylon, 6.5 oz. 210 denier oxford with heavy-duty polyurethane waterproofing
ºPoles: Aluminum alloy with shock-corded pole sections
ºOutside Pole Diameter: 13mm
ºRoof and Wall Mesh: Rugged 2.3 oz. poly filament 75 denier polyester knit, "no-see-um" roof
ºZippers: YKK-compatible nylon coil with corrosion-resistant nickel plated sliders
