part # of m416 u bolts
2010armygreen
Anyone have a part # for m416 axle u bolt? I have done research and from what I have found it seems that they are the same as the 50 cj3 rear axle ones. But still not 100% sure. I have emailed a few places and they don't seem to have an answer for me.
Thank You.
Mark Harley
· Shock Absorbers (2 per trailer):
NAPA 94038 $29 ea.
*this is for a mid 1970's CJ-5 with a 4cyl engine
· Springs:
1950's vintage CJ3A/CJ3B FRONT leaf springs (36.25x1.75 inch leaf springs)
· Spring Eye Bushings:
1950's CJ3A/B Front leaf bushings
· Shackles:
1950's vintage CJ3A/CJ3B shackles.
Note there is a right and a left threaded shackle. You'll need one of each.
Available from JC Whitney or any jeep parts specialist. These are commonly
called "c-shackles"
· U-bolts:
Again, 1950's CJ3A/B U-bolts for a Dana 25 axle. You want the "skinny" u-bolt
as there is also a wide u-bolt to clear the pumpkin on a D25. With nuts, they
run about 3.60 each from Willys Jeep Parts, Restoration & Wiring from Walck's 4 Wheel Drive | Willys CJ2a, CJ5, Willys Truck, Wagon & Jeepster parts
2010armygreen
It appears this is old info, walck's does not have any for $3.60 anymore and appear to be $10 or so but not sure if they are the right ones.
Digglesby
I recognize this is an old thread, but it came up first in my google search for this, so in case anyone comes here looking for this and has some uncertainty as I did, I was able to order from Walck's 4WD. It is part number A8578. I haven't received it yet to validate, but the measurements seem correct. If it turns out to be the wrong thing, I'll come back and update, but I feel good about it.
This link should take you to their search page result with this product: https://walcks4wd.com/catalogsearch/result/?q=A8578
Good luck, future people.
Digglesby
Parts arrived today and confirmed they are exactly the right bolts, and come with flat and lock washer and nuts to install.
