Partner Steel 22" 2 Burner Propane stove, shaved handle. [San Francisco Bay]
overlander
This is the stove i have. Great for rovers with rear safari doors that open to right
Sent from my SAMSUNG-SM-G891A using Tapatalk
jeep-N-montero
Ah shoot, I was about to PM you but noticed it was local pickup only. But a quick question, do you think a 12 inch cast iron skillet would fit with the wind screen? It states it will fit two 10 inch skillets, so maybe not.
if you pay shipping I suppose that could work, id just hate to add to the cost for you. I can test my lodge cast iron tonight if you're still interested.
Had you considered using a permanently installed tank?. n doing so you could route a propane hose through some of the Cable Chain. Add a shutoff solenoid in there and cooking could be as easy as pulling out the stove already hooked up, flip the switch to actuate the solenoid, lite the stove and cook. VS what we all do, pull out and position, attach hose at both ends, make sure stove is off, turn on valve, Lite, cook.
They use the cable chain on industrial equipment, blotters, and similar equipment. :)
My install will end up using the cable chain. Already putting in the rest of the system. Need to work on our slide out. We have the same stove FYI. Just was curious what the shaved handle was.
http://www.cableorganizer.com/cable-hose-carriers/
The problem is, the connection from the stove is custom and there is no way to adapt it to a 90degree bend, so the pop up cutting board hits it. Though once I get a left mounted hose, that is a fantastic idea!
JCDriller
Is this the standard 22" stove? All the photos online have the partner riveted emblem on the right side.
Anyway, I'm building a slide out kitchen for my 4runner and I'm in need of a partner stove with a right sided gas outlet. If you decide to ship, I'll take it.
Let me know. Here is what i'm working on.
JCDriller
Is that 3 sets of HD slide rails on one side, then another 2 sets fit the drawer and fridge...!?
I'm still finalizing the design but right now the drawer and large pullout holding the sink will be 36" accuride 9308s, the stove section is 26" accuride 9308s and the smaller utensils drawer/cutting board on the end is 26" accuride 3307s. Everything is lockout for stability. The fridge is on a easy slide ES100 drop slide shipped from Australia for ~660 usd.
Tiktaalik
Supporting Sponsor
I'm in the process of doing something similar. Have you posted this up in the "post up your storage system" section? I'd love too see how it turned out!
dhuss
