Pelican 1750
VanGo
SOLDPelican 1750 Protector Waterproof Rifle Case offers total protection for your hunting or tactical equipment. This Pelican gun case is unbreakable, watertight, airtight, dustproof, chemical resistant and corrosion-proof. Pelican builds this gun storage case from strong, durable Ultra High Impact structural copolymer. The Pelican Travel Vault 1750 Gun Case features an exclusive 1/4" (6.4 mm) neoprene o-ring, with ABS latches that seal perfectly. The gun case also includes an automatic purge valve for quick equalization after changes in atmospheric pressure. Pelican 1750 rifle case 1750 - watertight plastic container has transport wheels for better handling. Your equipment can fit into the high density foam of the rifle case for total protection against impact, vibration or shock. This Pelican rifle case is NATO codified and tested to MIL C-4150J (Military Standard), IP-67 (Ingress Protection) and ATA (Air Transportation Association).
Specifications for Pelican 1750 Waterproof Travel Vault Gun Case:
Exterior Dimensions (L x W x D): 53.00" x 16.00" x 6.12" (134.6 x 40.6 x 15.5 cm)
Interior Dimensions (L x W x D): 50.50" x 13.50" x 5.25" (128.2 x 34.3 x 13.3 cm)
Lid Depth: 1.75" (4.4 cm)
Bottom Depth: 3.50" (8.9 cm)
Total Depth: 5.25" (13.3 cm)
Weight w/ Foam: 25.57 lbs. (11.6 kg)
Weight w/o Foam: 23.59lbs. (10.7 kg)
Buoyancy Max.: 187.39 lbs. (85 kg)
Range Temperature: -10 / 210° F (-23 / 99° C)
No. of Wheels: 2
Pelican 1750 Case Certificates: IP67 * STANAG 4280
Features of Pelican Watertight Protective Rifle Cases 1750:
Watertight, crushproof, and dust proof
Open cell core with solid wall design - strong, light weight
Pressure Equalization Valve
O-ring seal
Fold down handles
Strong polyurethane wheels with stainless steel bearings
Stainless steel hardware
3-piece foam set
Unconditional Lifetime Guarantee of Excellence available through Pelican.
I have 2 of these cases (black, w/foam) in like new condition, $200./ea. shipped CONUS from 62225. PM for details.
VanGo
1 Case remains. Will consider equal trade value for scepter 20L fuel cans.
tacolex
it's a great case i have one in desert tan you wouldn't happen to have extra foam for it would ya. I hacked up one peice for a gun i had but since then sold the gun.
VanGo
Not this time around, try opticsplanet for a good deal.
Sure wish I had the spare cash, I have two rifles that would look great in one of those!
Open to trades of equal value, plus cash. I have one left and would like to move this one along.
Psyph
