Phoenix Camper Shell Pricing
awheeler
Here are the shell options from Phoenix. I hadn't seen these posted yet so here they are. I sure like the fit and look of the PULSE Phoenix model but that is a lot of cash for a shell!
Basic Shell…………...$6,995
Include as standard features:
*aluminum single weld frame (similar to other brands)
*aluminum siding and bead board insulation (similar to other brands)
*2” foam mattress queen folding with short cab over *side window
*two 12v incandescent ceiling lights *single layer liner *front picture window
*vinyl flooring *4 basic body sizes to choose from 6’ mini, 6.5’ full, 8’ full, 10’ full
Phoenix Pop up Shell Base price…….....$11,995
*double welded aluminum cage frame extruded DOW foam insulation core laminated composite
pro-flex construction…………………………………………………………………………….…..…value $995
*extended cab over with queen size 4” foam or air mattress bed…………………….….....value $399
*fully finished and lined under bed storage with flip prop hood holders……….……..…..value $489
*phoenix simple lift roof lift, spring loaded STEEL supports hold over 1500lbs of snow, can be
driven highway speeds while up, and includes windows at the front and back…..value $349
*screen entry door radius corner powder coat white with built in rain gutter……..…..value $235
*front slider window opens to about the size of your truck slider……………………...…..value $175
*three fixture L.E.D. 12v ceiling lighting uses less than one fifth the electricity…….…value $150
*privacy curtains for all windows with easy slide plastic track sliders.………………..…..value $199
*completely custom sized to fit your truck and your needs……………………………………value $499
*P.U.L.S.E aerodynamic molded fiberglass cab over standard or low profile choice...value $499
*P.U.L.S.E. sculpted hand rolled radius rear body corners…………………………………….value $199
*triple layer inslulated pop up liner with “thinsulate style” high density flexible active core
sealed top to the roof and bottom to the body, not a lay over snap on…….……value $475
*complete installation on your vehicle with phoenix’ exclusive heavy duty ratchet strap
tie down system includes 4 exterior bed access storage doors……………………...value $395
zhukoveli
