Picked up a pop up trailer
AaronK
1990 Starcraft. Not exactly an "expedition" trailer but it'll serve our needs well.
Sent from my OnePlus One using Tapatalk.
I just got a chance to get into mine this weekend. Looking at suspension options. It is currently set up in an axle-over-spring configuration (leaf springs). Flipping it to a spring over axle configuration looks like it would raise the frame about 4″. I’ll have to look into wheel/tire options. Trailers are pretty new to me and I don’t know how big of a wheel I can get with the same bolt pattern. I’d like to avoid swapping hubs.
Interior is in pretty good shape. All the upholstery and cabinets are intact. Still working on figuring out all the wiring. Logically, you’d have a large gauge positive and negative at the battery box and everything on the trailer would be bussed off that. Apparently Starcraft didn’t think that way and all the different systems (lights, furnace, and fridge) all have their own leads to the battery with ring connectors. Near as I can tell, it’s the factory wiring. No biggie, just some of the quirks we’re working through.
Discovered that the battery rack on the tongue isn’t big enough for the Group 31 box I bought. That’ll be getting refabbed soon.
Here’s some pictures of it popped.
Our dog, Dax, has claimed her bed
We camped out of tent trailer for close to 10 years. Did the axle flip and put on some larger tires/wheels. Walmart has tires/wheels already mounted that you can bolt on and go. It worked well and handled some mildly rough trails with no problem.
That's my longer term plan. Gonna see how big of a tire/wheel I can get for the stock hole spacing.
May I suggest you look closely at the frame and consider strengthening it where appropriate? Also, make sure the material used in the frame is sufficiently strong to stand up to your intended use. I drug a similar trailer from Fairbanks to Tacoma in 1979 when there was still about 400 miles of gravel on the Alaska Highway. At the east end of Kluane Lake, I noticed the trailer was tilted. Upon inspection, the cross frame member to which the front spring shackles were welded had torn loose from the side frame members, allowing the axle to move to the rear about 4 inches, in turn letting the right tire scrape on the wheel well and lose its air. I was able to get it into Haines Junction and $1,000 of welding later, got the frame sturdy enough to continue the trip. You may also want to upgrade the axle and springs at sometime depending on where you want to use the trailer. Hopefully, the data plate on the trailer has info on the axle and springs, but if not, the manufacturer's website should have that information.
It's a lot less expensive to beef up the frame in your driveway/garage/shop than it is halfway between the middle and the edge of nowhere.
Best wishes for a lot of happy times in that trailer. I sure enjoyed mine . . .
Good ideas. Axle has already been swapped. Factory was a torsion bar setup. It now has leaves. Not sure how much the axle is rated for. I'll crawl under and look for a tag when the ground dries out.
I don't intend to take it on anything hardcore. Mild forest service at worst.
2004 Starcraft 10RT
Purchased this 2004 Starcraft 10RT this Spring. Upgraded 12v system with dual 6v batteries wired in a series with a portable 80w, 15amp solar panel. Very pleased thus far!:safari-rig::smiley_drive:
Pictures are of our first trip May 20-22, 2016. Pike NF road 307 North side of Rampart Reservoir! Great view of Pikes Peak. Short hike to the reservoir! Nice trail around the lake!
Working on adding a 12v auxiliary outlet, usb and volt meter.
photo 2.jpgphoto 6.jpgphoto 1.jpg2004 Starcraft 10rt Interior.jpe6V Battery Tray 1.JPGBattery Tray 1.jpg2004 Starcraft 10rt M.jpgz4audc3.jpgSD532014.jpg
Nice looking setup, makes me lean back towards just buying something like that instead of going through with my off road trailer build. Depending on what I can find locally, and for what price, I'm debating finding something similar or building an off road trailer in the off season. I have to weigh the personal satisfaction of building my own and durability vs the ease/quickness of purchasing something already done, all while keeping it affordable! Especially since it's something I'll realistically only use a few times a year.
The ongoing struggle...
Jlbeats
