CYi5
After having my inner, outer, and pinion seals done, not to mention the wheel bearings, my pinion is leaking once again. Without going into too much detail on the problems with the other seals, this will be the 3rd pinion that needs to be worked on.
I was just curious if you have to remove the 3rd from the housing in order to change a pinion seal out. All of my other leaks have stopped (knock on wood), and would reeallly like to reduce the risk of opening them up again by pulling the 3rd out.
