Jerkeejoe
I'm an absolute noob when it comes to this stuff, but I've done a fair amount of research and think I have a setup that will work.
The idea is to have everything except for the fuse box and solar panels on/in a cart like this one: Rolling Cart so that I'll be able to take power dang near anywhere I can lug this setup. The solar panels will be hinged together to make a portable setup. The fuse box will be permanently mounted to the trailer.
I'm thinking I'll connect the charge controller to the fuse box and inverter using Anderson connectors or something similar so that I can simply unplug from the fuse box and be completely disconnected from the trailer. Not on the drawing are disconnect switches that I will wire between the solar and the charge controller and between the batteries and the charge controller.
