Plywood for roof rack flooring?
stewwalker
I am going to put a floor on my Surco Safari Roofrack. I know most overland guys prefer perforated plastic (chicken coop or dog kennel flooring) but I'm leaning more towards plywood. It's way easier for me to get. I have not seen many like this, so I'm wondering if there is a reason no one uses plywood. Yes it will be heavier than plastic, but is there any other reason no one does it?
I'll probably use a hole saw to lighten it up a bit and paint it with marine topside deck coating. Hopefully this will help protect it from the elements better than regular paint.
jeep-N-montero
Ever driven with a sail on top? It feels a tiny bit like that, the sheet of plywood "floats" with wind current and will make a lot of noise when empty, been there and done that.
redthies
Renaissance Redneck
I say try it out. If you put some holes in it to allow air to move around/through it, it may not be noisy. Otherwise, no reason not to do it in your climate. I would try it before painting. That way if it does make a bunch of noise, you are only out a few bucks, and not the time and money for paint too.
Smksignals
I had a plywood floor in my Conn Ferr rack. Size was 5x4 '. I covered it with roll on bed liner. Never had a problem with it.
Mark Harley
I vote varnished vintage Oak strips.
Lets the air flow but is stable to walk on.
xjaugie
I had a plywood floor in my Conn Ferr rack on XJ for several years. I had it sprayed with Rino Liner and never had a problem, wish I had thought of cutting a few holes in it, I like that idea.
gun45boat
I did the 4 x 8 sheet of plywood thing. I got the Marine plywood and painted it with Black rustoleum. I beeat the sh&t out of it for years!!!! I lasted about 5 years in the weather before it started to deteriorate. I say go for it.
GREENI
I use something in the uk called Wisa board, it's plywood with a grippy surface, they use it on truck decks and trailer flooring.
To stop rattle.. Which it did, I use steel conduit saddles, screwed from underneath...
eggman918
Marine plywood coated with polyester resin thinned with 1 part acetone to 2 parts resin will last forever coat it after you have cut it to fit and put the holes it it then paint,I have used that system
in boat repair with very good results.
Montereyman
My first choice would be what is called extruded metal sheeting with metal braces. For something that you buy at a local building supply store any oriented strand board like Advantec is going to do a much better job of not absorbing water and warping than even marine grade plywood. For smaller projects I love HDPE which is easy to cut and drill and very strong and stiff and never rots.
Erik N
+1
Also, you can add concentrated paint pigment to the batch to tint it, if you want.
Use 2 coats, let the first cure for a day to seal it, use the second to coat it.
And for god sakes do it outside, in the shade to avoid the fumes.
stewwalker
Finally finished my spring break project.
If I had to do it over again I would NOT put the holes in the top. Yes they are easy tie down points but it makes a humming noise around 65 MPH...
iStan814
