Poke a holw where?
dewhorse
I am looking to run power from the battery into the cab of my DII ('03) and was wondering where the best place to poke a hole would be? I will probably run 4 6 gauge wire in for my inverter(s).
thank you ahead of time
R_Lefebvre
IIRC, there is actually big empty rubber grommet on the drivers side, just above the brake rod. Just put a slit, pull the wire, and seal with RTV.
Mike_rupp
If you want to have a cleaner wire installation, use some firewall bushings. It's a heck of a lot nicer than goobering it up with RTV, not to mention that two 4 gauge wires probably won't fit through that one hole.
Goldenbora
