'Pop-Out' 60/40 Windows?
GaryMc
I'm hunting a set of 60/40 side door windows for my '99 Ford. Specifically I want the kind that pop-out at the bottom for ventilation. I have called several suppliers, done numerous searches and can't track any down.
I seem them all the time on conversion vans around town so I know they are available....
Anyone know where I can find some?
shawn_nj
My 09 e250 has a stock OEM window on the "60" door and opens from the bottom as you described. Very nice to have when parked, but LOUD if you drive with it open.
dsw4x4
Ford was not nice when it came to the pop out windows. The newer vans something like 08 and newer (don't quote me on that year) they stopped using the rear and the "40" door pop out windows I do not really know why. Here is the catch you can bolt those three pop outs into a newer van out of an older van the catch is the tint does not match and you have to use the older interior plastic trim ring to finish the interior of the door, and you guessed it the older trim is a slightly different color than the newer trim so those upper door frames will probably not match the rest of your interior you can use the complete older interior out of an older van to skirt this issue but you then run into the seatbelt issues with old and new seat belts changing designs in the way they mount to the van. I probably have a extra set of those windows laying around with the latches if your still interested let me know.
Derek
Clemtiger84
