This is a Colorado Camper Van High Top on a EB Ford installed about a week and half ago. It was installed on a van we had owned for 13 years and bought by someone near Sacramento. I offered to drive the van out to Loveland and wait for it to be completed. I coordinated with Derek and Matt prior to leaving San Francisco and when I arrived on Monday morning, the lift mechanism and top were ready for install. Start to finish was three full days. I was on my way back to SF on Thursday. The high top performed great on the way back, cruising between 65 and 85 mph. Hit cross winds and headwinds and there was no change in wind noise from the what I noted on the way out (stock roof). Fuel mileage seemed close to what it was on the way out over Hwy 80 and consistent with the range of MPG I experienced over 13 years and 50k miles with this van. I was very pleasantly surprised, as I expected some hit. It was only a couple of tenths, if that.
This install incorporated the latest changes CCV has incorporated over the past year since ours was done. The screens are now all zip down for wide open feeling if desired, the lighting has a second zone over the bed so cabin lights can be on while the two rear lights are off, and a USB charging port is installed at the head of the bed. The finish inside was superb, and on this passenger van the rear air ducting and A/C controls were relocated. Outside was white gel coat to match the white van.
Fitment in the gutters is very good, again, resting on the lip of the gutters like our mid Size top. It does require a slight easy nudge of about 1/4 inch mid span only on the passenger side to sit in the gutter. When the top is down the bulb seal remains in the gutter. The High Top is 19 inches tall from the gutter and has a bit more flair than the mid top. With the three Z-awning brackets installed (they clamp on the gutter), the middle bracket will guide the top right onto the edge of the gutter. Top goes up and down smoothly, level and straight, hold the button or use the remote. No straining of shoulders or neck which I experienced with the SMB manual tops.
The amount of room in a high top when the top is down was incredible! The ability to nearly stand straight up (5' 8" height), stow bags on top of the bed and over the cab with the top down, is simply amazing. The interior volume is the same as our Mid Size with the top up, it is when the top is down that the extra space really shines. If you clearance of the high top is something you can work with, it really is something to consider.
![IMG_5730[1].jpg IMG_5730[1].jpg](https://expeditionportal.com/forum/data/attachments/282/282024-040772eb06c6bc1d632728d7466d61e2.jpg)
![IMG_5718[1].jpg IMG_5718[1].jpg](https://expeditionportal.com/forum/data/attachments/282/282025-3b34d4500aff12af74aaf8f3d22e1c7b.jpg)
![IMG_5720[1].jpg IMG_5720[1].jpg](https://expeditionportal.com/forum/data/attachments/282/282026-b7cf67a94f2f1b8f103af8fdf67d1314.jpg)
