Post your RAM mounted gear!
carbon60
(I originally wrote most of this as a response to another thread, but then I thought I should start a new one.)
I am quite satisfied with my current setup, though the ergonomics could be improved:
The gear is an iPad 2 in an Otterbox Defender case and the control head for the Kenwood TM-V71A transceiver.
It's all RAM: seat bolt plate, flex arm, etc:
- RAM Mount Plastic Rail Base for Aluminum Flex Rod (RAM-B-309-5U)
- RAM Mount Plastic Short Arm B-Socket (RAP-B-201U-A)
- RAM Mount Diamond Plate with 1 inch Ball (RAP-B-238U)
- RAM Mount Universal 10 inch Tablet Mount Tab-Tite Cradle (RAM-HOL-TAB8U)
- RAM Mount Cradle Plate Vehicle Floor Mount 1.0 inch Ball (RAM-B-316-1-238U)
Some of those part numbers are actually "groups" of RAM parts, to make ordering simpler. You end up receiving everything seperately as a big pile of black bits. (Can be somewhat entertaining to figure out.) I find that some of RAM's choices are not ideal. For example, a kit might include the specific mount for a device (i.e. smartphone), the arm and the suction mount. But RAM makes a few different grades and lengths of arms, plus a couple strengths of suction mount. So, in hindsight, I would order the specific parts that I want.
Also visible in the photo is the mount I use for my iPhone:
- RAM Mount Universal X-Grip Locking Suction Cup Mount (RAM-B-166-UN7U)
And a mount for the not-visible DeLorme inReach:
- RAM Mount DeLorme inReach Lite Suction Mount (RAP-B-166-2-DEL2U)
The inReach mount, in hindsight, is not sturdy enough. I might have to upgrade that.
What other RAM mounts do people use? Post your photos!
A.
BrianTN
Here is my console:
For the most part I like it, but it will wobble some, likely due to the mud terrains.
BrianTN
I like how it can be customized. Right now it is setup as: CB, pocket, cup holders, cigarette plugs, and two rows of switches. Eventually the pocket will be switched to a ham radio and smaller pocket. My console is the longer version, with I think 19" of space to fill up.
I have the base bolted directly to the floor with the stock console bolt locations so I didn't need their brackets. Which is great because they don't offer them for the Tundra. A U shaped piece then bolts to the base, and the console unit bolts to that U shaped piece. This piece has multiple choices for height in front and rear to allow a slope if desired or pretty flat. With the mud terrains it does shake some, so I made some brackets that fit on the outside of the U piece. This did help a lot, but hasn't eliminated the shake entirely.
Looking back I do like it, and would probably go a similar route if I were to do it again.
BrianTN
A picture when I first installed the console, with my 897 on the front, which is no longer in the truck:
Some close up of switches installed:
I can get other pictures if you would like them. Some may be posted in my build thread somewhere.
lugueto
No pics but I mount a handheld GPS (Garmin 62s) using a suction cup mount, I just stick it to the windshield and remove it when not in used.
On my previous car I had no cupholders so I used RAM's swivelled cup holders using the same suction cupo on the windshield. I also had a 1" ball drilled to the dash where I stuck the same GPS.
Boost Creep
also run a seat mount with the x grip for an ipad mini. i found it was a bit wobbly so i too made a brace for mine to hold it steady
dhuss
