Posted on RV Trader.....2012 Global Expedition Safari Extreme w/major 2019 Factory Upgrades
Greg D
  • 2012 International Workstar 7500, 4X4 (on demand) Engine: MaxForce10-liter diesel, 310 hp, 1,050 lb-ft torque, NO DEF REQUIRED. Trans: Allison 3000 Rugged Duty Service, 5-speed automatic· Tires(new 2/19): Goodyear 425/65 R 22.5 · Brakes: Dual air 3-stage w/engine compression braking · Dual 70-gallon diesel fuel tanks· Seats: National 2000 w/Air suspension, leather, heated · Mileage: 76,000 miles · Serviced by International
  • Global Expedition Vehicle (GXV) SCS-Structural Composite Sandwich panels, 2.36"walls, 4.25"floor. Kinetic Mounting System: 4-point connection between the body and the chassis w/2 structural isolation bearing points & 2 pivot points. Cab-to-Cabin access. Armor Vision™ Premium Dual-Pane glass windows w/integrated shades and insect screens. Excellent thermal properties and noise filtering. (2) Dometic Skylight
  • INTERIOR Length186" Width91.5" Height79", Custom Black Handcrafted Cabinetry, Countertops: Solid Surface · Stainless steel sink, Webasto Cooktop, Double Burner · Marine grade Vitrifrigo® Stainless Steel 2-drawer 3.7 cuft. refrigerator / 2.7 cuft. freezer· Microwave/Convection Oven, Breville “grind & brew” Coffee maker, Dining Booth seats 4, converts to 2nd Sleeping Area (36” x 62’). Main Bed: Queen-size TemperPedic mattress, Wet Bath w/Shower · Thetford® Cassette Toilet · Teak Cabinets&Flooring: Commercial Vinyl (indestructible) · Walls: Custom woven Covering A/V· Two (2) LG LED HDTV Televisions on wall mounts · Power Accustik® System: CD, DVD, AM/FM, USB Outback® Electrical Power System · Marine-grade 2500w Inverter/Charger, 120v/60Hz · Solar Panels: 400w in 2 · New (2019) 270Ah AGM Lifeline Batteries, Qty 3 =810Ah · New 2019 Onan® QD 3200 Quiet Diesel generator. Webasto® Diesel Cabin & Hot Water Heaters · Dometic Low Profile Air Conditioner with Heat Strip, rooftop Vent Fan · 125g fresh water Supply protected· Water Filter System · Isotherm® Webasto Water Heater · 36 gallon Gray Water PolyTank
  • In March 2019, Global Expedition Vehicles performed a major body-off-frame restoration on this truck at their plant in Springfield Missouri; dramatically improving the cab-to-cabin access among other items. Work included complete rebuilding the access between truck cab and body and addition of a new plate and watertight seals between the cabin and the truck cab. A new Onan 3200 Quiet Diesel generator was installed along wiht additional work
  • Compare to a new Safari Extreme Base Price $560k OR Earthroamer LTI at $590kboth before ANY Options
