pot and pans
JR Greenhorn
Seasoning has been mentioned a few times in this thread--I wanted to pass along a tip:
The manual for my Blackstone Griddle recommends using shortening (e.g. Crisco) instead of oil or especially butter for seasoning. Butter is not recommended due to the ease at which it scorches or burns. Oil works, but shortening is easier to apply, and seems to polymerize thicker more quickly and easily than does multiple coats of oil. You do have to pre-heat the cookware to apply shortening, but I've heard that recommended even when seasoning with oil.
With my griddle, the burners have enough power to burn the seasoning directly above the burners, but I can easily re-season that area with some gobs of shortening dabbed onto the hot griddle with a thick wad of paper towels (don't let the hot shortening soak through and burn your hand after it liquifies!). The same approach should work to "spot-season" over a burner any seasoned cookware that has been previously overheated.
Note that most brands of shortening have been reformulated during the last several years to reduce trans fat.
Magma's recommendation to oven-heat pots and pans upside down while seasoning is a good one that had never occurred to me before. I have had polymerized oil gob up on cast iron pans before too, but I've always seasoned them "normal side up" in the oven. I'll have to keep that one in mind.
Beyond that, cooking up a package of bacon before cooking the remainder of the meal always seems to get the cooking surface just right, and definitely contributes to further seasoning. As if it is necessary to have a reason to make bacon?
taugust
I received my Magma ceramic set today. Very solid pans. The package weighed 15 pounds. I washed the pans, and cooked an omelette in the skillet without any oil. It came out of the pan perfectly. Very nice set. Water beads on the non-stick surface.
Corey
OverCamping Specialist
Glad you are liking it.
I made French Toast in my omelet pan last Sunday, and there was no cleanup afterwards.
A simple wipe with a paper towel and all was clean.
The pan at the bottom is a little narrow though, two pieces of toast and one had to rest on the side of the pan, but the heat cooked it OK.
cactusjk
Looking to get a set of the Magmas. Have heard the white nonstick is very easily scratched and discolors. I really only need nonstick on the frypan. Any suggestions?
spressomon
Using the Magma ceramic non-stick coating nesting pan set here without issue. But I don't use anything abrasive in the pan...same here for stainless though. Wood and silicone get it done. Before pulling trigger I went back/forth on SS or ceramic non-stick and low water use clean up was the end factor FWIW.
<edit> I haven't put enough heat & food through my Magma ceramic pan set for longer term surface durability feedback. PM Corey as I think he might have more use than most on his Magma ceramic pan set.
I cut large "disks" from felt fabric, sourced from a fabric store, to provide surface protection for the pans when in nesting & travel mode; works great.
cactusjk
Sounds good. I am leaning towards the grey Ceramica non-stick. I also only use wood and silicon utensils so should not be a problem. The nesting feature is perfect.
Accrete
thumbs up on the ceramic non-stick. We've been using ours for ~4 seasons with silicon utensils. Still going fine.
Thom
Tazman
I just bought the Magma Stainless. I have a couple of Magma BBQs and they make great stuff. I went with Stainless because it will last the rest of my life and then some. The non stick scare me from a durability and health standpoint. I almost went with the Ceramic but was concerned with durability.
Corey
My Magma is holding up fine.
I used the omelet pan for dinner Saturday night, simply wiped out the pan with a paper towel afterwards.
slomatt
The 7 piece stainless set has been on sale at Amazon for $81 recently. According to camelcamelcamel.com this is the lower price they've ever been sold at, so I bought a set to replace my beat up old non-stick pots and pans. They Magma's just arrived and I have not cooked using them yet, but I'm very impressed with the build quality. I also purchased the pot protectors to keep things from clattering while on the trail.
http://www.amazon.com/Magma-Gourmet...id=1455524986&sr=8-7&keywords=magma+stainless
http://camelcamelcamel.com/Magma-Gourmet-Nesting-Stainless-Cookware/product/B0049MFVG8
- Matt
cactusjk
I am also thinking this set is the way to go. Wish you could get just a ceramic nonstick frying pan. Any feedback on how easy to clean these are?
cactusjk
Back to the Ceramica set. Is there a big difference between the "induction" and non induction set? Looks like the non induction has been recently updated and I can't find it on Amazon.
grogie
Like to Camp
Thanks to this thread... I just received a set of the Magna ceramic non-stick pans for my camping setup. The set is more pieces then I need, but wow, nice! Someday maybe I'll have an RV that they can live in? They are nice! My wife for home cooking uses Le Creuset pans which also have ceramic coating, which we love (other then their weight). And these aren't as heavy!
I did not go with the induction versions (not sure if I'll ever have an induction range?), as I found the non versions on eBay for a very good price. I look forward to giving them a try!
cactusjk
We ended up with an Airstream so they should work perfectly!
