I just thought I would browse the expo site after not bothering with it for a couple years and low and behold I find a Dormobile resurrection project.
Some resources:
My Dormobile section
The Land Rover Dormobile mail list
Dormobile owners club - For all models of Dormobile & UK centric
Dormobile Ltd. - Many special Dormobile parts reproduced. You can even get complete new lifting roofs for 109 and 110 Land Rovers.
Or you can just
email me
and ask a question
The Salisbury is an essential item for a heavy 109 Dormobile. The Chevy 250 is the largest engine that
Scotty recommended to sit in front of a Series gearbox. If you ever decide to go larger you should
swap out the gearbox to a Chevy top loader light truck four speed. You didn't say but you should have one of the following:
Ashcroft high ratio converted transfercase,
Roamerdrive or
Heystee Automotive overdrive. 3.54 R&P gears will work but it will ruin your low range gearing.
Advance Adapters makes adapters to go between most popular gearboxes and the LR transfercase.
The stock gearbox is marginal for your engine so you need to be easy on the throttle . If you decide to go diesel,
Rob Davis has engineered a conversion for the Mercedes 617 five cylinder engine.
These are the resources that immediately come to mind. If you have any questions about your Dormie don't hesitate to shoot me an email. The Dormobile mail list can be VERY helpful with lots of how-to help. Good luck on your resurrection!
