power for my truck
tbared
Life participant
Alright i need a battery maintainer( it seems cold up here and out there and everywhere i travel), i need and inverter(wifes toys and putors) i need to be able to plug into shore power for heat in the box for puppies and to make sure batteries turn over come morning. i would LIKE them all in one. As for anything else im not sure at this point, any ideas?
how bout one of these to accomplish what i need.
http://www.xantrex.com/power-products/inverter-chargers/freedom-hf.aspx
4x4junkie
You want something to provide 110VAC from battery power, but will also recharge the batteries when plugged into shore power?
If so, that unit should work quite well (Xantrex seems to be a great name in such equipment, with customer support to match as well).
Keep in mind that running AC loads can add up very quickly on your batteries. If anything can possibly be run straight from 12V (cell-phone chargers, laptop computer, etc.), do so. That way you avoid what are called "Conversion losses" by not going through the inverter.
