Powerflares for safety
Corey
OverCamping Specialist
I hope this is the correct section for this.
These use LED lights instead of a flame like a regular road flare uses.
These come in two formats, a replaceable battery type (CR 123), and a rechargeable type.
At the time I wrote this, to get the rechargeable ones you must buy then in a six pack which comes with a case they all fit into and it plugs into a 12v outlet.
I got to use these at work on 1-16-2008.
I often move freight at work on a shuttle when it is dark out.
Workers come into work when it is still dark out, and I usually set out orange safety cones around my shuttle so they will see that the shuttle is there and not drive into it.
For the most part that works, but often workers drive in to fast, I guess they are in a hurry to find their favorite parking spot and get inside to get that first morning coffee.
I set one Powerflare on top of my safety cone, and it was visible clear at the other end of the parking lot.
I was really impressed with it.
Later in the day when it was light out I had to use the shuttle again over at the corporate building where they often drive in very fast too.
I set the Powerflare about 15' behind the shuttle so they would have plenty of warning that I was working there.
I talked to a few of them and they said they could see it very well and though it was a great idea for safety.
Here is a video I made at home showing the various patterns the Powerflare is capable of doing.
YouTube - Powerflare
I am going to dispose of my road flares I carry now as soon as I find out the correct way to dispose of them.
These Powerflares are a lot safer, and I can see many uses for them from working along side the road if your vehicle breaks down, in the back country where you need help, to using them at work like I did the other day.
They are also waterproof down to about 80', the number of uses for these you can come up with is many.
Links:
Website
Online store
Red/amber LEDs with orange shell (I ordered a yellow shell instead)
PDF file I scanned in of the brochure that came with them
ThomD
Cool. Thanks for the video. A couple of years ago when I was bicycle commuting I looked into these as a tail light. They were too new then to be able to order, but they looked very interesting.
Antichrist
Sounds like a great idea, but at $50US each, I'll stick to traditional flares. As seldom as I use them I can't justify that sort of cost. Even if someone drives over one of my reflective triangles, which hasn't happened yet in 30 years, it would still be cheaper to buy a new set of 3, than one of these.
ilciclista
