Nitromethane43
Just wondering if any one has some experience or ideas on how to alleviate the build up of water, sand, mud, and rocks in recessed areas of a vehicle. Prior to starting the rework of my truck I spent many hours washing off buckets of mud with a pressure washer. Then upon disassembly there were still tons of mud in areas that were covered up or did not have a direct line with a pressure washer. So before covering things up again i was wondering if there is anything that can be done to prevent the build up of debris and water in the recesses, voids, and other hidden areas allowing corrosion to form easier.
Below is an example, it rained and the water pooled in the dish and a week later there was still water in there, that's plastic, but there are still many areas on the factory frame that also collect water, sand and rocks.
I was throwing around the idea of maybe filling the recessed areas with some kind of paraffin or machine tooling wax to level out areas so at least nothing will collect, or maybe filling some areas on the frame with epoxy and making a nice fillet or transition so things will run off?
