Price Drop: 1991 Isuzu Trooper 3.4 Swap
tuckerj
Price Drop: Asking $2000 OBO.
For Sale is my 1991 Isuzu Trooper. I have owned this car for about the last 10 years. I bought it at 115,000 and it now has about 167,000 (odometer cable broke and shows 161,000). This was originally a California car and has been in Missouri for only a couple years. It sat in storage for the last 2 years. It had routine maintenance done on it while in storage. I also ripped out the carpet before it went into storage and had plans to rhino line the floor, but never did.
Pros:
3.4L V6 Swap
Independent4x ball joint spacer
Independent4x HD Tie Rods
Manual Locking Hub Swap
CB Radio
New heads in the last 5,000
New Mickey Thompson Deegan 38s (32x11.5x15) in the last 5,000
New Battery in the last 5,000
New Alternator in the last 10,000
Cons:
Speedometer/Odometer Cable went out about 6000-7000 miles ago (odometer does not reflect actual mileage). Throws CEL while driving for this
Driveshaft yoke needs replaced
Needs alignment
Needs the lash adjusted on one or two valves. After 500 miles on the new heads an adjustment is required. I did the adjustment but could not get it quite right and haven't had the time to fix it (only affects driving while in 5th gear on the freeway under heavy load)
Has minor leak in windshield ($100 fix for gasket)
Has exhaust leak between manifold and down pipe due to cross threaded bolt
Just had drivers side fender repaired from school bus backing into it while parked. No other damage was caused. This car is not perfect, but is in excellent shape for a 1991 Isuzu Trooper. Located in Waynesville, MO
JonBannan
What 3.4L V6 did you swap it with? I have this same year/configuration trooper and my brother in law just burned out my transmission. Figured I’d replace the transmission and engine all in one go. Any info you have on this swap would be greatly appreciated!
travelall74
