*Price drop* 1995 Mitsubishi Montero LS, 188k miles, super clean - $5200
digory
1995 Mitsubishi Montero LS 4-door
  • 188,068 miles
  • 3.0L V6
  • 4WD ActiveTrac (2WD, AWD, traditional 4 Hi/Lo with center locking diff)
  • 2 owners
  • PNW owned its entire life (Washington & Oregon)
  • Sunroof
I bought this Montero from the original owner in October 2019, and have added 27k miles since then. I’ve spent countless hours restoring this vehicle over the years, to make it look nearly new. It’s taken me across the country on a 4000 mile road trip, without issue, and all around the Pacific Northwest. It’s been lightly off-roaded on forest roads, but most all its time has been on-road.
Around town, I get 14-17 mpg depending on if I’m in AWD or 2WD. On the highway, I’ve gotten as high as 21 mpg, but 17-19 is typical.
A lot of service has been performed by local Montero expert, Sean Kendall (if you know, you know!). Otherwise, I’ve taken it to a local import specialist.
A/C blows cold! Heat is hot! Clean title, no liens.
Located in Bend, Oregon.
I’m a bit reluctant to let ol’ Monty go, as he’s been really good to me and the family, but I bought a truck…
Some of the modifications:
  • K&N air filter
  • LED dash lights
  • Leather-wrapped steering wheel
  • Bilstein 4600 shocks
  • Pioneer bluetooth stereo (I loved the OEM deck w/ cassette, but it died)
  • Blind spot mirror (I can't live without these)
  • Optima Red Top battery
  • Big cup holders (custom 3D printed one goes into the ashtray slot)
  • RAM Mounts ball on Oh-No bar
  • Pitch/roll indicator (not wired to lighting)
  • Well Visors
Known issues:
  • Brake pads are at 5 and 6 mm (need replacing when at 3-4; next owner may want to do the "big brake" kit that a lot of Montero owners do)
  • Front differential pinion seal is starting to seep fluid; will need replacement if leak worsens
  • Chips in paint; small rust spots in paint
  • Tear in rear seat armrest fabric
  • Driver’s headlight lens gets condensation
  • Tail light fuse occasionally blows (hasn’t happened in several thousand miles)
  • Piston rings have lost their spring force on the engine walls, so when using engine braking (e.g. in 3rd gear when descending mountains) oil is pulled past the rings, resulting in bluish puffy exhaust. No driveway leaks, and no smoke during normal use. These could be replaced and the engine would basically be brand-new afterwards. (Ballpark from Sean was $3k) -- I wasn't going to mess with it until I had leaks or it used oil. It might go for years like it is!
Partial recent service history:
  • New tires, Cooper Discoverer AT3 (161k) – 8/32 left as of Aug 2023
  • A/C belt, alternator belt, power steering belt, Adventure Driven Design idler bushings, pitman arm, outer/inner tie rods, idler arm (163k)
  • Valve stem seals, timing belt, spark plugs/wires, seals, gaskets, exhaust manifold, valve covers, power steering flush, coolant flush, lifters (168k)
    • doesn't show up on CarFax as done by Sean (and Import Performance keeps asking if the timing belt was done -- it was!)
  • Rear axle pinion seal, fuel filter (180k)
  • Chevron Techron fuel treatment (183k)
  • Oil change, tire rotation (188k)
CarFax report and recent inpsection are attached.
(CarFax thinks there were 2 owners prior to me, but the previous owner told me he was the original owner -- it it definitely was not a rental as CarFax has it under his ownership.)
Other items included in sale:
  • 3 keys
  • Yakima rack keys
  • Owner’s manual
  • Full service records
  • Hub covers
  • K&N recharge kit
Asking $5200 OBO
More photos here
  • CARFAX Vehicle History Report for this 1995 MITSUBISHI MONTERO LS_ JA4MR41H4SJ028202.pdf
  • Import Performance Inspection.pdf
gp01
