*PRICE DROP* 2010 Toyota Tacoma TRD Off-road, asking $25k OBO or trade
icanhithimman
2010 Toyota Tacoma, SR5, 4x4, AT, TRD-OFF ROAD
Truck has 104,345 miles currently but will go up. All regular maintenance preformed in accordance with factory recommendations. Logbook and receipts included. This is a mall crawler; it was too small for my needs by the time it was built out. I have not modified the truck electrically at all. The paint is good. There is no rust. I have removed the TRD stickers.
MODIFICATIONS
Frame is epoxy coated on the exterior with Eastwood products 2k coatings. Interior is also coated with Eastwood products. Cosmoline is applied over epoxy coatings.
Rear of frame is boxed with a kit from DMZ Fabrication. All work was performed by NYS/AWS certified welder.
Power Stop big brake kit.
ECGS differential busing installed.
Bilstein 6112 shocks in the front with King 700-pound coils and JBA Heavy Duty upper control arms. Springs from Bilstein included.
Rear Add-a-leaf from ICON Off-road. Factory springs were replaced in accordance with Toyota TSP recall. Shocks are Bilstein 5160 remote reservoir. Bump stops are ICON.
Bay Area Metal Fabrication rear shackle hangers and shackles (greaseable).
ARB bumper with ComeUp SEAL GEN 2-SLIM 9500 lbs winch and synthetic line. Factor 55 fairlead and link.
RCI Off-road Front, mid and transmission skid plates, steel.
Gas tank skid from Victory 4x4.
fumoto valve is installed at engine oil access door.
Rear differential breather modification.
Cab mount chop performed by aforementioned welder to accommodate larger tires.
MarlinCrawler Heavy Duty Lower Control Arm Frame Brace Kit is welded in place. The hard part of RCLT modification, the rest is bolt on. If you choose to continue with the upgrade, you could run up to a 37” tire.
Rock sliders are from are bolted on from RSG Metal Works. Flat model with kickout, full top plate and grips.
Decked system is installed with included storage boxes, dividers, locks and drains.
Jeraco Cab-High Truck Cap (latches need to be replaced).
Seat covers are from Marathon.
Floor mats are Weather Tech.
Mudflaps from RokBloz (Second shorter height set included).
A Bird Dog Industries Tech Deck Ram ball mount is installed under the radio.
Victory 4x4 center console MOLLE panels (Not installed).
JBA Cat-back exhaust.
Two sets of factory Toyota wheels 17” and 16” are included. TRD Off-road wheels and TRD sport wheels. Two CV axels are provided as spares.
Seat jackets on front seats.
Truck is in excellent condition with over $15,000 in additional parts and has never been on the trails.
More photos in link below.
YaRiteZ71
