*Price Reduced* 2005 Toyota 4Runner Limited 4x4 W/ 2021 Off Grid Trailers Expedition 2.0 $55,000
Martiny505
Turn Key, Off-Grid, Expedition Ready Overland Truck and Trailer
This rig needs to be on an adventure!!!
looking for that perfect rig for overland travel?
a rock solid, PROVEN set up with fewer electrical components to trouble shoot
that won't break the bank and isn't a brand new, shiny target on your back...
You've found your UNICORN!!
*Package Only* will not separate
$55,000 USD - OBO -
You won't find a better deal on a solid set up like this
Towed by a
V8 (2UZ-FE)
Miles: 13X,XXX (these engines known to go 500k+ miles)
Automatic Transmission
4 Wheel Drive
Current location: Santa Fe, NEW Mexico, USA
NO ACCIDENTS, CLEAN TITLE in hand
THE GOODS
Truck Details
Non smoking vehicle
  • Routine maintenance following Toyota service guide
  • Timing belt replaced at 92k miles
  • Transmission: Automatic
  • Manual Transfer Case - Full-time 4WD, 4WD LOW, Locking Mid Differential
  • Fuel: Gas
  • A/C: A/C blows cold!
  • Heat: Toasty Hot!
  • Custom cargo area drawer storage
    • General Features
      • Full Monstaliner on exterior surfaces
      • Alu-cab tilting fridge slide
      • Airline style tie downs (L-Track)
      • Locking drawer slides rated to +300lbs
      • Driver side drawer (20Wx36Lx11D)
    • Electrical
      • Dometic CFX3 55 IM
      • 12V Auxiliary Renogy Hybrid GEL, 100Ah
      • Redarc Dual Input 25A In-Vehicle DC-DC Charger
      • Solar input routed to rear bumper
      • Lighting on inner rear hatch door
      • 100 Watt solar panel
    • Cooking
      • 22-Inch 2-burner Partner Stove with wind guards
      • Secondary drawer for prep surface and additional storage
  • Spare Tire Swing - 80% Off-Road
    • Power Tanks 5lb propane bracket
    • 5lb Manchester propane tank
    • Trasharoo
  • Low profile winch mount -Lost Trail
    • Warn VR Evo 12-S
    • Factor 55 - FlatLink - WLL 16,000lbs
  • Sherpa Equipment Company Roof Rack - The Princeton
    • Load Rating
      • 300lb Dynamic
      • 600lb Static
    • Shovel mount
    • Antenna for Midland GMRS
    • 100 Watt solar panel mounted
  • Suspension Upgrade
    • 2” Fox Suspension Lift Kit Front and Rear
    • Total Chaos Upper Control Arms
    • Heavy load springs rear
    • AIr bag load assist
  • Auxiliary Systems
    • ARB Twin Air Compressor
      • Air chucks in engine bay and at rear of truck
    • Redarc Tow-Pro Elite Electric Brake Controller
    • Fire Extinguisher - H3R HalGuard Clean Agent Automotive w/ Seat mount, located on passenger side seat
    • Long Range America - 24 Gallon auxiliary fuel tank w. Transfer pump and dash mounted level indicator
    • Custom dash bar for mounting RAM mounted iPad
    • Midland MXT275 MicroMobile
  • Wheels and Tires
    • ProComp 34 Series Rockwell - 17” (to match trailer allowing more emergency spares)
    • Falken Wildpeak A/T AT3W 255/80R17 E-Load
  • Factory Features
    • 2” Rear Hitch Receiver
    • 4 and 7 Pin Trailer Harness Plug Connector
    • Power Windows, Mirrors, Door locks and Driver and Passenger Seat
    • Heated front seats
    • A/C and Heat work perfectly
    • Cruise Control
    • Interior Dash Digital Temp Sensor with average MPG
    • OEM heavy duty rubber floor mats (front and rear)
2021 Off Grid Trailer Expedition 2.0
Specs
  • Dry Weight: 1700 LBS
  • Tongue Weight: 290 LBS
  • MAX GVW: 3500 LBS
  • Departure Angle: 50 Degrees
  • Ground Clearance: 21″ | 25″ w/ Evolution Series Suspension
  • Overall Width: 89 Inches
  • Overall Height: 79″ | 83″ w/ Evolution Series Suspension
  • Wheelbase: 120 Inches
  • Track Width: 76 Inches
  • Interior Headroom: 46.5 Inches
  • Interior Length: 80 Inches
  • Interior Width: 56.5 Inches
  • Fresh Water Capacity: 31 Gal.
  • Mattress Size: Queen
  • Rear Exterior Cabinets: 15″x27″‘x56″
  • Interior Cabinets: 28″x14″x56″
OEM Features
  • 360 degree Maxcoupler Hitch (Receiver and Tow vehicle adapter)
  • XO Jack
  • Independent Timbren Susspension
  • Furnace (6500BTU)
  • Dometic CFX3 55IM
  • Maxxfan Deluxe 7500 fan upgrade (thermostat, electric lift, remote)
  • Spare tire mounting plate
  • 11lb Propane Cylinder
  • On demand hot water heater
  • 23Zero Shower stall
TRAILER UPGRADES:
  • Matching Flaken Wildpeak A/T AT3W 255/80R17 E-Load
  • (3) 100 Watt Solar Panels (300 total watts) with Zamp port for additional panels
  • Battle Born 2 x 100Ah 12V LiFePO4 Heated Batteries
  • Redarc Dual Input 40A In-Vehicle DC-DC MPPT Charger
  • Victron Energy BMV-712 Smart Battery Monitor
  • Terrapod RTTx XL clamshell style tent
  • Exped Megamat Duo 10 (trailer cabin) and DeepSleep Duo 7.5 (RTT)
  • Overland Pros Wraptor 270 Awning - Passenger side
  • Front Runner Pro Stainless Steel Camp Table and Mount
  • Lifetime adjustable height table
  • Partner Steel 18" 2 Burner Propane Stove With Windscreen
  • Custom spice rack in galley
  • Custom under sink/stove dish drying rack
  • H3R MaxOut Dry Chemical Automotive Fire Extinguisher w/ Extreme Duty Mount
  • RLD Design Lion Boxes (rebranded frontrunner boxes)
  • Custom blackout insulated window coverings
THE LOW DOWN
TRUCK
Rock solid and no known issues - mechanical or otherwise - except as stated here:
• Typical Toyota clear coat cracking, fading, and peeling, particularly on the hood and in a few other areas. - Price reduced in consideration
• Body is in excellent shape! Some minor door dings and scratch on rear passenger side but no dents and no accidents.
  • Interior is in good shape with the exception of driver seat cover tearing.
• Some surface rust on underbelly - nothing corrosive and none on the body
TRAILER
Rock solid and no known issues - mechanical or otherwise - except as stated above
Anything else you want to know, any other photos or video - please ask.
Thanks for looking!
Martiny505
More pictures
Martiny505
More pictures
sunnyaz
