PRICE UPDATE: ARB High Performance Air Compressor (New) - CKMA12
This is an over-purchase. The compressor has never been mounted or taken out of the box.
UPDATE: $250 SHIPPING INCLUDED TO CONTINENTAL US
Compact design makes it the highest flowing compressor in its class (voltage vs size)
Fully sealed components for moisture and dust
Pressure switch controlled air manifold systems specially designed to suit ARB Air Locker equipped vehicles
Hard anodized cylinder bore and PTFE (Teflon) impregnated carbon fiber piston seal for reduced friction and maximum trouble free life
New anodized mounting bracket dissipates motor heat and allows compresor to be repositioned 180°
Anti-vibration sound deadening mount
Relocatable splash resistant air filter assembly for cleaner, cooler air supply and versatile waterproof air intake positioning
High densisty, high flow washable sintered bronze air filter element
Maxi-Fuse equipped for professional in-line circuit protection
Motor is 100% ball bearing equipped with unique linear brush pre-load system for extra long life, low heat and quiet operation
Compressor piston is equipped with a German made high shock rated cylindrical roller bearing
Constructed entirely of light weight, high strenght engineering grade materials, including military and aerospace grade components
Over-pressure safety valve equipped
Motor is internally thermal protected against extreme temperature damage
I am located in Belmont, CA, 94002.
The package weighs 10.5 lbs.
It fits into the USPS Medium Sized Flat Rate box. Shipping included in the price the continental US
Includes
  • Full-assembled and bench-tested air compressor
  • Complete snap-together wiring loom
  • OEM quality compressor isolating switch
  • Air Locker supply-rated pressure switch
  • Relocatable splash-resistant air filter with washable high-flow sintered bronze filter cartridge
  • Mounting hardware with reinforcing backing plate
  • Comprehensive photo illustrated installation guide
No lowball offers, please.
Scotty
dhuss
