Propane Distribution Tree + 2 coleman 8' hoses ....... $70 shipped
adam88
I am selling a Century Propane Distribution Tree + Two Coleman 8' hoses that I bought from Amazon. These are in perfect like-new condition, I only used them once. For those unfamiliar with a propane tree, basically it hooks up to any 20lb (or 30lb/40lb) propane tank and you can run a lantern off it (screwed into the top), plus 2 other propane appliances (using the hoses). So for instance you can run a lantern+stove+mr buddy heater off of a single 20lb propane tank. You could also run a on demand propane hot water shower or even a propane cooler.
For info, here are the links to the exact items I am selling:
https://www.amazon.com/Century-Two-Piece-18-30-Type-Safety/dp/B0007LQ26S
https://www.amazon.com/Coleman-8-Ft-High-Pressure-Propane-Hose/dp/B0009PUQBO/?th=1&psc=1
Asking $70 shipped
adam88
Do you know if the hose fits or can be easily adapted to Camp Chef grills? I may be interested.
Hey. The hoses have female ends which means they will screw into anything that a 1lb propane bottle would screw into. I am pretty sure it would work with a camp chef but not positive... but if not all you would need is an adapter to screw into in. If camp chef models work with a 1lb propane bottle then it will definitely work.
dhuss
