PROPEX HS2211 with IKamper Skycamp Mini RTT (with annex)
Mark2457
Hi All
Considering a PROPEX HS2211 to get safe, long running, thermostatically controlled heating in my roof top tent for winter camping.
I have a 2020 Ford Ranger with ZROADZ overland access bedrack. I can attach the heat exchanger to the bed rack, leave the propane in the truck bed (nearby) and just run the air output to the tent.
A few concerns
  1. The manual says you should only run a max of 4 feet of hose to the first outlet
  2. The inlet and exhaust lines cannot be extended
I can mount the tent so that I have about a foot of the bed track free at the back, so I could mount the unit there. The inlet and exhaust would then be fully external. and I'd have to run the air hose to up through the window I guess
Anyone done anything like this? Any tips or other things to watch out for?
Thanks
Mark
ttengineer
Propane is a very wet heat (humidity will be an issue), I’d look into diesel personally. Esuif you are planning on an external mount.
highwest
You’re right about Buddy heaters and those other catalytic-types, but in this case, a Propex is a forced air heat exchanger arrangement just like a diesel heater. Both diesel (Espar, Planar, Webasto, Chinese) and Propex are good considerations here.
ttengineer
Ah, I was not aware it was a heat exchange.
Never mind then, I stand corrected.
iStan814
