Pump cycle no key?
TexasTJ
Climbing Nerd
I went out to take a hike to day I drove about 30 miles and when I stopped the Rover and took out the key There was a nose form under the hood that sounded like a pump cycling. No key Rover off. I popped the hood to have a look around and it sounded like it was coming from the front of the motor or maybe around the radiator. after about two minutes it stopped. when I got back in the rover and turned the key it started again right before the 4.0 turned over. drover home fine and didn't do it when I stopped at home. anyone have any idea what that might have been? I driver the Rover about 80 miles round trip evey weekend to go climbing and its never done this before.
thanks
Nate :smiley_drive:
evilfij
Fans will run after you shut it down if it is really hot (like this is a bad thing). Are you low on coolant?
TexasTJ
Climbing Nerd
Ill check the coolant that was my first thought. It was 98 in Austin yesterday. but then I was fine for the same driver home and the temp gauge never spiked.
thanks
Nate
TexasTJ
Climbing Nerd
would there be anything wrong with a auto store home flush kit?? I hand handle that just fine. I really don't want to have to pull the radiator.
Clemtiger84
