Putting in new gear on 2002 tundra what else while in there?
Skinhyfish
Going with EcGS gears and getting install done.. while having truck torn apart, is there anything you would recommend changing or servicing while torn down? Seals? Upgrades?
Thanks Zach
bkg
Flush brake lines (you'll have to disconnect the rear, most likely, to get the axles out far enough to pull the diff).
check lines to front diff disconnect
Check the condition of the CV.
Brakes
Clemtiger84
