Question about 3/4 ton M101 trailer..
brennanriddle1
What are the dimensions of the chassis of an m101 a1 trailer?
Looking to purchase one from govliquidation.com.
The plan is to build a teardrop style camper on top that is off road capable. I just need to know if it's long enough to sleep on. I'm 6 ft.
fj40fax
If you are 72" long and the trailer is 76" long, that doesn't seem like enough room to sleep to me. I'm 74" and my sleeping bag that I bottom out is 86" long. Remember that you point your toes when you sleep, and you need a few extra inches for your fluffy pillow.
jeeper92
Wow
I almost bought one of these a few months ago. I thoguht about it and then thought it would be too damn heavy for a jeep. What are your thoughts.? I wont be doign any off roading in it.
jagular7
I used the M101 US Mil trailer frame as a basis for a trailer to put a truck camper on. It is 96" long and short of 45" wide for the basis of a trailer frame.
I strongly suggest that you replace the heavy tongue, axle and tires with something more appropriate.
I added the front tongue from a box boat trailer frame. I added a Dexter 3500# axle with brakes and 14" tires using the stock leafs. I added 2x3x.25 to fit inside the boat tongue and went back to 2 crossmembers. I think this single post added a lot of weight to the trailer. I estimate the rolling trailer to weigh 800#s.
I added a Quicksilver truck camper on top. Its a canvas top slide in camper. It was 79" overall length.
You can also get rid of the leafs, but this ran so well I kept them. I would look at removing totally or replacing the crossmembers with something lighter but keeping the exterior of the frame secured. They are welded in. The major frame is welded together, the tongue is bolted on, and the suspension is riveted on. I drilled the frame to be able to adjust the axle 20" forward/back at 5" intervals.
I just recently sold the camper/trailer. It was 1300#s empty (camper 450#s) and was a bit much for my 4cyl TJ with coolers, clothing, firewood, Jeep spares, and tools.
I'm working now on an idea with a PWC trailer and looking to add a long bed fiberglass contractor work topper. I'll add a base and sides and bolt it on the frame. It has dual rear doors and 2 large side access doors. I'm looking to build slide out cabinets behind those access doors.
This should be a lot lighter. I'm also changing the 4cyl out for a 4.3l in the Jeep. That will take some time.
brennanriddle1
I know the m101 is heavy but i'm looking for very sturdy construction as i plan to take it off the beaten path quite a bit. Nothing too hard, a few decent sized rocks here and there maybe.
The tow vehicle is a 2007 JK Rubicon with a 3.8L V6 and 4.88's on 35's. (Soon to be 37's). I know the stock rubicon brakes are all disc and are very strong, so i'm hoping they will not be an issue.
And as for the tires and wheels; the plan is to eventually get matching 17" Soft 8s and 35" tires so that will hopefully drop the weight a little bit.
