millerfish
So I picked up a set of steel wheels. Not sure what they came off of. The backspace is .5" less that my factory spare and the same width. The truck is a 2014 DC SB TRD OR. The wheels are marked as follows
New wheels
J 16X7JJDOT CMC 2 01 HM 19
HM – FE – 15
Factory spare
J 16X7 JJ DOT CMC 2 14 WT 20
WT – FE - 24
My questions are:
Can I assume the factory spare is the same spec as the factory alloys?
Will the .5" less backspace be an issue?
What are the small rectangle pieces welded to the wheel next to the valve? Can I remove them prior to powder coat or should I leave them be?
New wheels
HM – FE – 15
Factory spare
WT – FE - 24
My questions are:
