questions about my future build
geo_jeep
I am in the planning/research stage and my future trailer build and I have a question for everyone. I am going to be pulling it behind my Jeep Wrangler as a way to carry all my gear. My question is, as I am starting a "wish list", if you were making a perfect trailer, what would you make sure you had on it? Things like water storage, extra fuel,............anything that you would have. Any info would be great. Thanks!
78Bronco
Lever actuated e-brake. Adjustable tongue length. Same bolt pattern, wheels and tires as the tow vehicle + spare.
corrected my spelling error
socaljeeper
I think some of the things that I use most when at camp with my trailer are the fridge, built in 12 volt lighting, flat usable space, and the sink with running water.
TacoDell
...3500# axle W/10" e-brake
...strong fully boxed frame
...a receiver tube running full length OC
...Lock and Roll hitch (for the above receiver)
...Extended tongue length to clear vehicle at 90* backing
...axle hub, wheels and tires to match the hauler's
...a cover that seals and secures the load
all the other frills are dependent on how you intend to utilize your junk.
But before I would go worrying about the comfort sissy gadgets...
I'd want to be sure the trailer's base is up to the rigors. JMO
flipstick
