questions about power layout
dpike
so i came up with the rough sketch for me that also seems pretty typical, but i'm a little overwhelmed about what is actually needed to do this.
what controller can do this ?
what fuse box is good for connections like this ?
what size fuse should be on the two batteries ?
i'd need about 15' of cable from the starter battery to the controller, what size should this be ?
is the bus bar needed or could everything just be grounded to the fuse box or house battery ?
should the ground on the controller be to the starter battery or a chassis ground somewhere ?
should the house battery also be grounded to the chassis ?
should the fuse box be grounded to the battery or the bus bar ?
dhuss
