Rain Shower 2 brand new
goinsurfin
Brand new Road Shower 2, holds 5 gallons of water
Description below:
Mount it to the roof rack on your car or SUV
Great to use for washing off after a day at the beach, wash off bikes, boards and other gear.
It's Powder coated aluminum that absorbs sunlight and heats the water inside.
holds 5 gallons of water…enough for 2-3 showers.
sleek design and and high end compenents look great on your vehicle.
on/off valve at elbow so you can easily remove the hose or attach a longer hose while pressurized.
Shrader style air valve so you can pressurize it on the go. -locking loop to lock your unit with a cable style bike lock to your rack.
LCD thermometer which will show you the temperature in F and C.
beefy universal mounting brackets mount to most racks.
Specifications
Dimensions: 56.5″ x 7″ x 5″.
Slot Channel is 55″ long and the mounting bolts can be moved over this entire length.
Holds 5 gallons of water.
Empty Weight: 15 lbs.
Full weight: 55 lbs.
Hose length is 55″.
$300 NEW. Buyer pays shipping or pick up in Miami FL
goinsurfin
used stock photos to show RS2 and photo of box. IMG_0721.JPGIMG_0719.JPGIMG_0720.JPGIMG_0722.JPG
Petersmithinak
