RAM mounts for 5th gen T4R
jgatliff
Father, Husband, Outdoorsman, & Adventurer.
Does anyone know of an easy way to utilize ram mounts in the 5th gen?
I’d like to mount my iPad mini, phone, to pro and a few other things.
In my 15 taco I had the Bird Dawg a tech Deck and I see that you can get the TPAM mount for 3rd gen tacos. But I haven’t found a solution for 5th gen 4Runners. Any help would be really appreciated!
Dalko43
I use the suction cup version of the Ram mount. I know some people say to avoid those, but I've had mine constantly attached to my windshield for 1-2 years now. It only fell off once; i cleaned the window and the suction cup, put it back on haven't had a problem since.
I understand the utility of a more permanent attachment method, but if you want the ability to add or remove mounts, the Ram suction mount works very well.
Doc_
Sammich!
I've bolted the ball mounts into my door cards as permanent mounting points:
Glue was mentioned earlier, that seems like a good idea, same with the suction cup mounts.
Do you think you might be able to mod a Pana-Vise mount for a fourth-gen to fit your fifth-gen?
https://www.panavise.com/pdf_indash/75137-303.pdf
Wareagle
I used the metal two screw bases on my 2018 4R ORP. One is mounted is same spot as link for iPhone using x mount. The other is placed on side of transmission tunnel housing for the iPads mount.
YaRiteZ71
