Ramsey winches...Anyone use them?
kojackJKU
Autism Family Travellers!
I am getting the winch mount for the front of the patriot this spring, and I am looking for a compact 6000lb winch. The ramsey model looks great. Anyone have a Ramsey winch and what are your thoughts?
aardvarcus
I have looked at 6,000 lb winches before, more for weight savings to make it easier to move on a receiver carrier.
The Ramsey model seems a bit heavy for a 6000 lb winch at 84lbs without cable, and looking deeper it appears to be built on the same platform as their patriot 8000 and 9000 series as it has similar dimensions, weight, and look, with less capacity but more line speed. That tells me they are the same winch with different gearsets. Looking at the parts numbers in the manual confirms my suspicion, as most of the replacement parts numbers are identical except for the gearsets. So that is an 8000 lb winch with a different gearset to increase line speed but limit capacity. At that point, I would just opt for an 8000 lb winch.
If you are looking for a lighter and smaller 6000lb winch, look at the comeup DV-6s. It is a bit narrower(18.1x6.3x10.1 versus 22.7 x 6.1 x 9.9 ), and weighs exactly half at 42lb with cable than the Ramsey does without cable.
kojackJKU
I am looking at a 6000 because of exactly what you mentioned. Lightweight, compact dimensions etc. I only need 6000 as my rig is only 3300 lbs. And really it will be used more for moving trees etc than pulling the jeep out of mud, but incase I need it, its available.
kraven
Hegelian Scum
One of my amigos has been using Ramsey for years on his Jeep. Never had any failures, and his rig is locked, lifted, etc. He uses it for crawling and recovery.
Happy Joe
Apprentice Geezer
Used a Ramsey 8,000 pounder (mostly on friends and strangers) for near 20 years then got a deal on a newer used Warn 8000; sold the Ramsey for the cost of the used Warn...I like the Warn slightly better (its faster) but have no complaints about the Ramsey.
Enjoy!
Houie
