Range Rover III
jdholder
Does anybody wheel one? It's what I have - and therefore what I will be taking into the southern California desert.
I know the weaknesses with air suspension, and cooling system - anything else I should be worried about?
timmy!!!!!!!
Weak sidewalls on the tires. On my very first wheeling trip back in 04 a RRIII sliced it's tire in a bad spot. Also didn't they have a front driveshaft issue?
Life_in_4Lo
jdholder,
OT
Not that the RR isn't nice but why did you get rid of the Excursion? That was so nicely built up!
on-topic
There is nothing really difficult in the desert. Does the RR have good skidplates? If the airbags fail, you could be a low-rider getting out.
jdholder
jdholder,
OT
New job afforded me absolutely NO time to camp at all - I knew it would be at least a year before it opened up again. We had three cars, so I couldn't stand having the Excursion sitting around - and a member here wanted it - and I knew it would get used.
on-topic
I need to get under the RR to see what hangs low! I am thinking about how to alleviate the problem if the air suspension fails - I am going to see if Timbren makes a rubber spring that might replace the factory RR bump stops to alleviate some issues.
lexwoody
I used to wheel my 04 all the time with the low pro tires. No issue. most of my issue (drive tran) came from freeway or in city driving. But I wish there was a coil spring conversion kit like there is now when I was wheeling my RR. Check out some of these videos.
http://www.toyota120.com/forum/showthread.php?p=82463#post82463
I still have my genuine LR expedition roof rack and ladder if there is any takes.
timmy!!!!!!!
I was looking underneath my dads excursion a few days ago (well doing some work) and I noticed that the frames aren't fully boxed. Now I know your RR is a unibody but I know my disco has a fully boxed frame.
Goldenbora
