rear axle tech question
zukrider
so i have an SR without a rear locker. not sure, but i believe it is still a 9.5 axle.
my question is, has anyone swapped a locked diff in? i can get the third a lot cheaper than a whole axle, though the whole will provide spare shafts!
whatcha think? now that its all dented up, i see no reason to hold back! story of my life!
off-roader
Have you checked the Mitsu ASA program to verify which diff you have? I'd do that before buying another diff to swap in. If it is a 9.5" diff, then there's no reason a locked 3rd member wouldn't be swappable. You'd have to also add the LP compressor and check for any required wiring & switches you need to incorporate if the aren't already there.
IIRC, the stock locker also has a lockout feature disabling/enabling it depending on what mode you've selected in the transfer case.
zukrider
i planned on running my own wiring, bypassing the lock out feature. will attempt to tie into the cluster though, so the light will work.
i am not sure what the ASA program is?
Houie
